Re: equinox in a web application in and outside of an rcp application [message #77955 is a reply to message #77939] |
Fri, 24 November 2006 14:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
See
http://www.eclipse.org/equinox/server/http_quickstart.php
for using Equinox in server configurations
Jeff
Wouter de Vaal wrote:
> I would like to know whether is possible to start equinox without the
> eclipse executable. I would like to use it within a web application, but
> without having to run the web application osgi centric as is described
> in the quick starts for serving servlets with equinox (as a matter of
> fact I am only using filters).
> This webapplication will run within tomcat or jetty (depending on
> clustering capabilities).
> Also the web application will run partly within an eclipse RCP
> application, so then it would probably a good idea to use the standard
> eclipse runtime environment for it's osgi capabilities within the same
> web application.
> Any thoughts on this?
> Wouter
FUDForum. Page generated in 0.04390 seconds
