Home » Eclipse Projects » Equinox » bundle autoloading
bundle autoloading [message #77923] Fri, 24 November 2006 10:02
Wouter de Vaal is currently offline Wouter de VaalFriend
I would like to be able to autoload bundles into my osgi registry.
From the equinox page there is a suggestion to use
eclipse runtime and update, so I guess it's not directly embedded in
equinox.
"Now, if you want to make things even easier, you can add in a few
Eclipse bundles (i.e., org.eclipse.core.runtime and
org.eclipse.update.configurator). This gives you an application model,
automatic bundle discovery/install, extension registry, ... Standard
Eclipse tooling configurations use this approach. See the Eclipse
plug-in list for plug-ins that may be useful to you."
http://www.eclipse.org/equinox/documents/quickstart.php
However I can't really find good documentation on which parts to use
and how to use it, does anybody have some pointers for me on this?
Thanx,
Wouter
Previous Topic:Startup order effecting servlet registration classloader
Next Topic:equinox in a web application in and outside of an rcp application
Current Time: Sat Nov 09 00:21:02 GMT 2024
Powered by FUDForum. Page generated in 0.02468 seconds
