| Page NullPointerException when trying to register a listener [message #6986] |
Mon, 16 June 2008 04:21  |
Originally posted by: franzi483.web.de
Hello!
I am writing a plug-in for Eclipse, and I want to register a
PartListener which implements IPartListener2 when a particular view of
my plug-in is created.
I try to achieve this by the following code:
createPartControl(Composite c) {
IWorkbenchWindow workbenchWindow;
IWorkbenchPage page;
IWorkbench wbench = PlatformUI.getWorkbench();
workbenchWindow = wbench.getActiveWorkbenchWindow();
page = workbenchWindow.getActivePage();
if (partListener == null) {
partListener = new PartListener();
page.addPartListener(partListener);
But it always returns me a NullPointerException in the line
page.addPartListener as page is null.
I've tried the same code in the plugin initialization (in method
start(BundleContext b)). There it randomly shows a NullPointerException.
Any idea why the page is null?
Thank you in advance for any advice.
| Re: Page NullPointerException when trying to register a listener [message #7031 is a reply to message #6986] |
Mon, 16 June 2008 10:00  |
FWIW, this sort of question probably belongs in eclipse.platform.
Wayne
On Mon, 2008-06-16 at 10:21 +0200, Franz Brenner wrote:
> Hello!
| Re: Page NullPointerException when trying to register a listener [message #569063 is a reply to message #6986] |
Mon, 16 June 2008 09:59  |
With the activator, you're probably running into a thread issue. Only
the UI thread can call getActiveWorkbenchWindow() (checkout the comments
in Workbench#getActiveWorkbenchWindow()).
Try instead something like:
page = getSite().getPage();
Not sure if it will help, but it will make the code tighter (and more
correct).
Wayne
> Hello!
| Re: Page NullPointerException when trying to register a listener [message #569099 is a reply to message #6986] |
Wayne
> Hello!
FUDForum. Page generated in 0.04173 seconds
