| New build for Teneo, release notes (0.8.0 - 0.7.5) [message #77754] | Fri, 30 March 2007 18:01 |  |
| Eclipse User  |  |  |  |  | New builds are available for Teneo: 0.8.0 and 0.7.5.
 >>> Build 0.8.0. (for build 0.7.5 see below)
 The latest 0.8.0 build contains the following new/changed functionality:
 - Proxying and Class name mapping (hibernate)
 Teneo will now as a default add a (class)name attribute to each class mapping in Hibernate. This
 makes it also possible to query for types using  class(names) and interfaces(names). This behavior
 is enabled as a default (as there are no apparent disadvantages) but can be disabled by setting an
 option (PersistenceOptions.ALSO_MAP_AS_CLASS).
 This release should now also support Hibernate (or cglib) proxies. This means that lazy-loading for
 many-to-one relations is now supported.
 There is a new option SET_PROXY (default: false) which controls if Teneo will make each type
 proxy-able (for each concrete type). Proxying for specific types can be enabled by using the @Proxy
 annotation (which is also new).
 Thanks to Jean-Denis Boudreault for contributing in this area.
 - Multiple Inheritance
 The last few weeks I have seen a number of examples of multiple inheritance combined with Teneo. A
 number of issues related to this have been solved earlir and this build contains several additional
 fixes related to multiple inheritance handling.
 However as jpox/hibernate do not support multiple-inheritance there are still limitations. For more
 information please visit these pages:
 http://www.elver.org/hibernate/inheritance.html#Multiple+Inh eritance+Support
 http://www.elver.org/jpox/inheritance.html#Multiple+Inherita nce+Support
 - Href
 When an object refers another eobject in another resource and the first object is persisted to xml
 then the reference to the second object is stored as a href-like id. The href is now set correctly
 and contains the primary key of the refered-to object.
 - Issues solved for 0.8.0
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=177369 - Implement a new system option to enable full
 classificati...
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=177370 - Implement the @Proxy annotation
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=179313 - Column annotation attribute "nullable" is not
 being consi...
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=179446 - EMF Referencing (using resource uri and
 object id) from a...
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=180011 - Feature id of PersistableEList can be wrong
 in case of mu...
 >>> Build 0.7.5
 The fixes for multiple inheritance also apply to the 0.7.5 release. The 0.7.5 release does not
 support Hibernate proxying.
 The 0.7.5 release for jpox now runs with jpox 1.1.7.
 Issues solved for 0.7.5
 in case of mu...
 With Regards, Martin Taal
 Springsite/Elver.org
 The Netherlands
 Tel: +31 (0)84 420 2397
 Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.03934 seconds
