Home » Language IDEs » ServerTools (WTP) » Can't start Tomcat
Can't start Tomcat [message #77687] |
Sun, 27 February 2005 14:16 |
Originally posted by: fassev.gmx.de
I downloaded and installed the new M3 build of the WTP and created a new
Web Project as showed in the Tutorial "WTP Tutorials - Building a School
Schedule Web Application". Everything goes ok, except that I am not able
to start the Tomcat 5.0. I am getting Class not found Exceltion :
java.lang.NoClassDefFoundError: org/apache/catalina/startup/Bootstrap
Looking at the Tomcat v5.0 runtim configuration within my project, I do
not see the bootstrap.jar, commons-launcher.jar, commons-daemmon.jar - all
of them laying in the Tomcat5.0/bin directory.
What I am doing wrong?
Best Regards
Peter
Re: Can't start Tomcat [message #77807 is a reply to message #77687] |
Sun, 27 February 2005 22:00 |
Originally posted by: muhammad.dwyer.gmail.com
I have exactly the same problem and exactly the same error. It just doesn't
seem to be neatly integrated the way WSDK 5.1 was in Eclipse 2. I'm hoping
the next release should address this issue, otherwise I'm lost.
> Hello,
> new Web Project as showed in the Tutorial "WTP Tutorials - Building a
> School Schedule Web Application". Everything goes ok, except that I am
> not able to start the Tomcat 5.0. I am getting Class not found
> Exceltion :
> do not see the bootstrap.jar, commons-launcher.jar,
> commons-daemmon.jar - all of them laying in the Tomcat5.0/bin
> directory.
> Best Regards
> Peter
Re: Can't start Tomcat [message #78736 is a reply to message #78505] |
Tue, 01 March 2005 19:33 |
Hello Lawrence,
My tomcat installation directory is E:\jakarta-tomcat-5.0.28\ - this is also
how I entered it in the "Edit Server Runtime" dialog - otherwise eclipse
won't let you get any further.
> Hi Peter,
> Are you specifying the root directory of you Tomcat install as the
> install location? If so, what is the directory name? There was a post
> above that suggested the directory name must be as creates it when you
> unzip.
> Lawrence
>> Hello,
>> am not able to start the Tomcat 5.0. I am getting Class not found
>> Exceltion :
> all
>> Best Regards
>> Peter
Re: Can't start Tomcat [message #78794 is a reply to message #78736] |
Tue, 01 March 2005 21:09 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
I was able to duplicate this. Drop the trailing '\' and just use
"E:\jakarta-tomcat-5.0.28" and it should work. The extra '\' causes the
launch configuration to contain "...\bin\" rather than
"...\bin\bootstrap.jar" in the classpath.
You can either delete and re-create the server, or execute Window ->
Preferences and select Server -> Installed Runtimes -> "your runtime"
and click Edit. Remove the trailing '\' from the installation directory
and save.
I'll see about logging a defect and providing a patch.
Larry
Muhammad Dwyer wrote:
> Hello Lawrence,
> also how I entered it in the "Edit Server Runtime" dialog - otherwise
> eclipse won't let you get any further.
>> Hi Peter,
>> unzip.
>> Lawrence
>>> Hello,
>>> Exceltion :
>> all
>>> Best Regards
>>> Peter
Re: Can't start Tomcat [message #78824 is a reply to message #78794] |
Tue, 01 March 2005 21:31 |
Dear Larry,
Thank you very much! I've now got my first JSP running on Tomcat under Eclipse!
I can now move onto some more serious stuff. Excellent, thanks again.
Kind regards,
Muhammad
> the launch configuration to contain "...\bin\" rather than
> directory and save.
> Cheers,
> Larry
>> Hello Lawrence,
>> is also how I entered it in the "Edit Server Runtime" dialog -
>> otherwise eclipse won't let you get any further.
>>> Hi Peter,
>>> post above that suggested the directory name must be as creates it
>>> when you unzip.
>>> Lawrence
>>>> Hello,
>>>> a new Web Project as showed in the Tutorial "WTP Tutorials -
>>>> Building a School Schedule Web Application". Everything goes ok,
>>>> except that I am not able to start the Tomcat 5.0. I am getting
>>>> I do not see the bootstrap.jar, commons-launcher.jar,
>>> all
>>>> Best Regards
>>>> Peter
Re: Can't start Tomcat [message #79069 is a reply to message #78794] |
Wed, 02 March 2005 13:58 |
I've entered <https://bugs.eclipse.org/bugs/show_bug.cgi?id=86988> for
this bug.
Larry
> and save.
> Cheers,
> Larry
>> Hello Lawrence,
>>> Hi Peter,
>>> unzip.
>>> Lawrence
>>>> Hello,
>>>> Exceltion :
>>> all
>>>> Best Regards
>>>> Peter
Re: Can't start Tomcat [message #79983 is a reply to message #79069] |
Thu, 03 March 2005 22:20 |
Hello Larry,
I've noticed that eclipse 3.1 (I was first working with 3.0.1) doesn't add
a backslah to the end of the server path by default, which makes life a little
easier :)
Muhammad
> this bug.
> Larry
>> directory and save.
>> Cheers,
>> Larry
>>> Hello Lawrence,
>>>> Hi Peter,
>>>> when you unzip.
>>>> Lawrence
>>>>> Hello,
>>>> all
>>>>> Best Regards
>>>>> Peter
Current Time: Thu Dec 26 20:10:08 GMT 2024
Powered by FUDForum. Page generated in 0.04467 seconds
