Mixing Eclipse .2.1 and WSAD [message #77678] |
Fri, 18 July 2003 12:08 |
Originally posted by: dcorbin.imperitek.com
I have a friend that is stuck on a team using WSAD. Our team uses
Eclipse. Now, I don't know excactly what plugins from WSAD they
actually use, but it is it practical to copy those over to an Eclipse
install, and use all the Eclipse 2.1 features with a handful of WSAD
plugins?
David
Re: Mixing Eclipse .2.1 and WSAD [message #77868 is a reply to message #77775] |
Fri, 18 July 2003 15:57 |
Originally posted by: richkulp.NOSPAM.us.ibm.com
It is not "most likely will not work". It is a definite, with no
exception, will not work. The next WSAD that works on Eclipse 2.1.1 is
in process. As per usual IBM policy, no dates are permitted to be given
out until the proper time.
Rich
FUDForum. Page generated in 0.03831 seconds
