Home » Archived » EPF » EPF Composer 1.0-M2-I20060411
EPF Composer 1.0-M2-I20060411 [message #6956] Wed, 12 April 2006 22:05 Go to next message
James E Thario is currently offline James E TharioFriend
Member
Hello.
A new integration build of EPF Composer is available for download and
testing. The EPF team would very much appreciate any help the community
can provide testing this build as we work toward providing a 1.0-M2
build toward the end of the week.
EPF Composer builds are available here:
http://www.eclipse.org/epf/downloads/tool/tool_downloads.php
Please post defects and enhancement requests here:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EPF
Thanks in advance!
Re: EPF Composer 1.0-M2-I20060411 [message #6979 is a reply to message #6956] Thu, 13 April 2006 09:54 Go to previous messageGo to next message
Originally posted by: michel.loehr.saxsys.de
Does the search capability already work with this version?
If yes, how do I get it to work? Will it appear in the top navigation
section?
Any help will be appricated!
Michel
Re: EPF Composer 1.0-M2-I20060411 [message #7029 is a reply to message #6979] Thu, 13 April 2006 14:53 Go to previous messageGo to next message
Member
From within EPF Composer, I can use the Search dialog, select the
Method Search tab and search for a term like "iteration" with the BUP
library loaded. It returns results in the Search view at the bottom of
the workspace window.
Method Search is not on the Search menu. Selecting the File or Search
(ctrl-h) menu item will bring up the dialog so I can select Method Search.
Does this answer your question?
Thanks.
> section?
> Cheers,
> Michel
Re: EPF Composer 1.0-M2-I20060411 [message #7076 is a reply to message #7029] Thu, 13 April 2006 17:23 Go to previous message
No,
I didn't mean within the EPF tool, but within the published website.
Re: EPF Composer 1.0-M2-I20060411 [message #562324 is a reply to message #6956] Thu, 13 April 2006 09:54 Go to previous message
section?
Michel
Re: EPF Composer 1.0-M2-I20060411 [message #562379 is a reply to message #6979] Thu, 13 April 2006 14:53 Go to previous message
Member
Thanks.
> section?
> Cheers,
> Michel
Re: EPF Composer 1.0-M2-I20060411 [message #562426 is a reply to message #7029] Thu, 13 April 2006 17:23 Go to previous message
No,
Previous Topic:Terminal Server support?
Next Topic:Terminal Server support?
Current Time: Sat Nov 09 03:58:48 GMT 2024
Powered by FUDForum. Page generated in 0.05897 seconds
