Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Getting started, can't set dependency copmonent type
[buckminster-dev] Getting started, can't set dependency copmonent type [message #6955] |
Thu, 06 March 2008 12:26 |
Rich Scott Messages: 63 Registered: July 2009 |
Member |
------_=_NextPart_001_01C87F85.42DCA30C
Content-Type: text/plain;
charset="us-ascii"
=20
I'm just getting started with Buckminster and trying to work through the
Building an Update Site example at
http://wiki.eclipse.org/Buckminster/Examples/Building_an_Upd ate_Site .
=20
I have the latest Buckminster installed into 3.3.2 with subversive. In
the instructions for building a CSPEC for the update site, the section
on Dependencies (item 2.4) indicates that I should set the Component
Type to "eclipse.feature". However, "eclipse.feature" is not an option
in the selection list. The only options that I see are:
=20
bom
buckminster
jar
site.feature
unknown
=20
Should I be using "site.feature", or is something missing in my install?
=20
Thanks for your help
Rich Scott
=20
Content-Type: text/html;
charset="us-ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"PersonName"/>
<!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hello,<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p >
font-family:Arial'>I’m just getting started with Buckminster and =
trying
to work through the Building an Update Site example at <a
href=3D" http://wiki.eclipse.org/Buckminster/Examples/Building_an_Upd ate_S=
ite"> http://wiki.eclipse.org/Buckminster/Examples/Building_an_Upd ate_Site=
</a>
..<o:p></o:p></span></font></p>
font-family:Arial'>I have the latest Buckminster installed into 3.3.2 =
with
subversive. In the instructions for building a CSPEC for the update =
site, the
section on Dependencies (item 2.4) indicates that I should set the =
Component
Type to “eclipse.feature”. However, =
“eclipse.feature”
is not an option in the selection list. The only options that I see =
are:<o:p></o:p></span></font></p>
font-family:Arial'> =
“”<o:p></o:p></span></font></p>
bom<o:p></o:p></span></font></p>
buckminster<o:p></o:p></span></font></p>
jar<o:p></o:p></span></font></p>
site.feature<o:p></o:p></span></font></p>
unknown<o:p></o:p></span></font></p>
font-family:Arial'>Should I be using “site.feature”, or is
something missing in my install?<o:p></o:p></span></font></p>
font-family:Arial'>Thanks for your help<o:p></o:p></span></font></p>
<p class=3DMsoNormal><st1:PersonName w:st=3D"on"><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Rich =
Scott</span></font></st1:PersonName><font
style=3D'font-size:10.0pt;font-family:Arial'><o:p></o:p></span ></font></p=
</div>
</body>
</html>
------_=_NextPart_001_01C87F85.42DCA30C--
Re: [buckminster-dev] Getting started, can't set dependency copmonent type [message #6978 is a reply to message #6955] |
Thu, 06 March 2008 14:59 |
Hi Scott,
Given the list of component types that you see, I don't think you have the Buckminster PDE support
installed. Either that, or it's not enabled for some reason.
The PDE support is required when working with plug-ins, features, and update sites.
Kind Regards,
Thomas Hallgren
Scott, Rich wrote:
> Hello,
> I’m just getting started with Buckminster and trying to work through the
> Type to “eclipse.feature”. However, “eclipse.feature” is not an option
> bom
> buckminster
> jar
> site.feature
> unknown
> Should I be using “site.feature”, or is something missing in my install?
> Rich Scott
RE: [buckminster-dev] Getting started, can't set dependency copmonenttype [message #7004 is a reply to message #6955] |
Thu, 06 March 2008 15:01 |
Member |
Thomas,
You are right. I missed that on the update site. That took care of the
problem.
Thanks for your help.
Rich Scott
-----Original Message-----
[mailto:buckminster-dev-bounces@eclipse.org] On Behalf Of Thomas
Hallgren
Sent: Thursday, March 06, 2008 10:00 AM
To: Buckminster developer discussions
Subject: Re: [buckminster-dev] Getting started, can't set dependency
copmonenttype
Hi Scott,
update sites.
Kind Regards,
Thomas Hallgren
Scott, Rich wrote:
> Hello,
the
option
> bom
> buckminster
> jar
> site.feature
> unknown
install?
> Rich Scott
_______________________________________________
buckminster-dev mailing list
buckminster-dev@eclipse.org
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Current Time: Sun Dec 22 05:40:30 GMT 2024
Powered by FUDForum. Page generated in 0.05636 seconds
