Home » Archived » BIRT » Line Charts
Line Charts [message #77402] Tue, 27 September 2005 16:34 Go to next message
Andy Lawton is currently offline Andy LawtonFriend
I have a line chart where I want to plot data along the Y axis that comes
from the result of a query. So far, so good. Just set the Y Series to
row["MyData"]. However I don't care about the X Series - I just want to plot
and have maybe 1,2,3,4, etc along the X axis. I don't have this data as the
result of a query. How can I calculate this for the chart, and can you show
every n'th X value, to stop the X axis being too cluttered?
Andy
Re: Line Charts [message #77449 is a reply to message #77402] Wed, 28 September 2005 13:03 Go to previous messageGo to next message
David Michonneau is currently offline David MichonneauFriend
Hi Andy,
Your best option right now is not to show the X labels at all, you can hide
them in the X Axis -> Labels page. Otherwise you would need to create a
computed column in your Query. Note that labels might be cluttered on the X
Axis, to avoid that, rotate them vertically. The next version of the Chart
(BIRT 2) will fix that problem.
David
"Andy" <andy.lawton@siemens.com> wrote in message
news:dhbs9s$4rn$1@news.eclipse.org...
>plot and have maybe 1,2,3,4, etc along the X axis. I don't have this data
>as the result of a query. How can I calculate this for the chart, and can
>you show every n'th X value, to stop the X axis being too cluttered?
> Thanks
> Andy
Re: Line Charts [message #78377 is a reply to message #77449] Mon, 03 October 2005 09:14 Go to previous message
That seems to do the trick!
Thanks.
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:dhe4bd$1kb$1@news.eclipse.org...
> Hi Andy,
> hide them in the X Axis -> Labels page. Otherwise you would need to create
> a computed column in your Query. Note that labels might be cluttered on
> the X Axis, to avoid that, rotate them vertically. The next version of the
> Chart (BIRT 2) will fix that problem.
> David
>> Thanks
>> Andy
Previous Topic:A data view is not available
Next Topic:performances with 50000 rows flat file datasource
Current Time: Sat Dec 21 12:55:45 GMT 2024
Powered by FUDForum. Page generated in 0.03064 seconds
