| Text Field in HTML Format [message #76995] | Mon, 26 September 2005 08:18  |  |
| Eclipse User  |  |  |  |  | Originally posted by: coquel.yahoo.fr
 I am having trouble using text fields in HTML format.
 When I include a parameter, it add a whitespace before and after the
 parameter :
 "someText<VALUE-OF>params["paramsName"]</VALUE-OF>, someText"  --> "someTexte
 [param] , someText"
 I also have troubles with cumulative text formating tags. It doesn't close
 properly the tags :
 "someText<B><I><VALUE-OF>params["paramsName"]</VALUE-OF ></I></B>, someText" .
 In this case, the bold tag is never closed.
 I get this trace :
 line 3 column 122 - Warning: inserting implicit <b>
 line 3 column 122 - Warning: inserting implicit <i>
 line 3 column 145 - Warning: replacing unexpected </value-of> by </i>
 line 3 column 156 - Warning: replacing unexpected </i> by </b>
 line 3 column 160 - Warning: missing </value-of> before </b>
 line 3 column 160 - Warning: replacing unexpected </b> by </i>
 line 5 column 62 - Warning: missing </b>
 Thanks in advance,
 Nicolas
| Re: Text Field in HTML Format [message #77309 is a reply to message #77293] | Tue, 27 September 2005 09:57  |  |
| Eclipse User  |  |  |  |  | Nicolas, I see what you mean.  There is a similar bug reported, but this one may be
 different.
 The number is 104173.
 If you can please add your comments to the case.
 I dont think this will help your problem, but you can add two strings in on
 VALUE-OF line.
 Like
 <VALUE-OF>params["civilite"]</VALUE-OF> <VALUE-OF>params["nom"]</VALUE-OF>
 Could be
 <VALUE-OF>params["civilite"] + params["nom"]</VALUE-OF>
 Jason Weathersby
 BIRT PMC
 "Nicolas Coquel" <coqueln@yahoo.fr> wrote in message
 news:035e1a216fc4c1d2f190fc93a4b9bdd2$1@www.eclipse.org...
 > I'm using the following configuration : Birt 1_0_1
 > Eclipse 3.0.1
 > Using a regular expression doesn't work, my parameter doesn't contain any
 > whitespace.
 > There is a difference between generating html or PDF reports:
 >  - HTML : the whitespace is not add when there is no text formating tags
 > (bolding ...).
 >  - HTML : the whitespace is add when I use text formating tags.
 >  - PDF : the whitespace is always add.
 > My Text Item full content :
 > <VALUE-OF>params["nom"]</VALUE-OF><BR>
 > <BR>
 > Lors de notre r
FUDForum. Page generated in 0.03673 seconds
