Re: Copy/Paste building blocks of a model file [message #77012 is a reply to message #76992] |
Mon, 13 November 2006 10:25 |
Originally posted by: jr.joergreuter.ch
High Balraj,
I'm stuck with the same issue.
It seems that clipboard support works well when you use a single file for
model and diagram. If you you use two files the Xerxes Parser crashes when
loading the diagram during the paste operation. This could be the reason why
nothing happens.
It seems to me that the entire clipboard package only supports a single file
for clipboard operation. On the other hand this clipboard support is quite
advanced in taking care of differenciating exactly what to copy and what
not. So it would be not an easy task to reach the same level of
sophistication when you start an own implementation.
J
Re: Copy/Paste building blocks of a model file [message #78039 is a reply to message #77327] |
Wed, 15 November 2006 22:08 |
I use now a different approach:
I keep diagram and model in the same file and have installed a builder to
generate "pure" model files of different kinds. This suits my needs very
well.
But there is also a limitation in the "single file solution". Clipboard
works only on the canvas level. So if you have nested figures and
compartments it does not work when you copy an inner figure and paste it
elsewhere. But this could be still a problem with my implementation.
J
FUDForum. Page generated in 0.03130 seconds
