content assist stopped working [message #76938] |
Thu, 17 July 2003 07:21 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: lists-nospam.thewoolleyweb.com
I am using 2.1.0. All of a sudden, my content assist (ctrl-space) stopped
working.
In Window/Preferences/Workbench/Keys/ Edit/Content Assist, it is still set
to ctrl-space for Standard, and Standard is my active configuration.
I have eclipse installed on another computer with a similar config (I
actually cloned this eclipse dir from that PC), and content assist still
works on that PC.
What else can I try to turn content assist back on?
Chad
Re: content assist stopped working [message #76998 is a reply to message #76938] |
Thu, 17 July 2003 09:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: daniel.megert.gmx.net
>working.
>works on that PC.
Did it stop working directly after cloning?
Dani
Re: content assist stopped working [message #77203 is a reply to message #76998] |
Thu, 17 July 2003 16:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No, it worked fine for a few months, and just stopped recently. About the
same time, I did install JDK 1.4, and start working on some JDK 1.4
projects in Eclipse. Could that be related?
Chad
Daniel Megert wrote:
> >working.
> >works on that PC.
> Dani
Re: content assist stopped working [message #77218 is a reply to message #77203] |
Thu, 17 July 2003 16:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Thu, 17 Jul 2003 16:30:57 +0000 (UTC),
Did you recompile Eclipse source using a 1.4 VM?
Olivier
Re: content assist stopped working [message #77314 is a reply to message #77218] |
Thu, 17 July 2003 19:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
No, I didn't recompile eclipse at all. I am using the standard win32
2.1.0 distribution.
I am just using the 4.1 JVM for some of my projects within eclipse.
-- Chad
> Olivier
FUDForum. Page generated in 0.04417 seconds
