Generate XML File option missing [message #76904] |
Sat, 31 January 2009 04:28 |
Originally posted by: nospam.pookmail.com
I downloaded and installed the JEE edition of Ganymede Eclipse on 1/29.
After editing an XSD file I right-clicked on the file, expecting to see
the "Generate" menu option so I could select "XML File" from the
sub-menu to create a file from the schema. The option is not there.
What do I need to add to get this back? It was there in prior versions.
Any help is appreciated.
T
Re: Generate XML File option missing [message #76935 is a reply to message #76921] |
Sat, 31 January 2009 18:40 |
I apologize for the cross-post but really did not know which group to
post to. There are so many groups and there no descriptions on what
should go where.
So far no response at WTP...
Thanks.
Ed Merks wrote:
> Todd,
> Please don't cross post the same question as separate postings to
> multiple groups. If you must cross post, use a single posting. In this
> case, WTP is the right place to ask because they provide that
> functionality so I can't really help explain why it would go missing...
>> see the "Generate" menu option so I could select "XML File" from the
>> Thanks,
>> T
Re: Generate XML File option missing [message #603614 is a reply to message #76904] |
Sat, 31 January 2009 13:08 |
Ed Merks Messages: 33236 Registered: July 2009 |
Todd,
> T
Ed Merks
FUDForum. Page generated in 0.03459 seconds
