Re: VE and Custom-Widgets [message #76911 is a reply to message #76864] |
Fri, 14 January 2005 18:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
As long as your constructor is
xyz(Composite parent, int style)
Then we should be able to handle it.
Tom Schindl wrote:
> David Orme wrote:
>> The way SWT itself does this sort of thing is to subclass either
>> Canvas or Composite and draw or embed the other control inside. See
>> CLabel, CCombo, etc. (the classes that begin with an extra 'C'.
>> If you subclass Composite, you can even use VE to design your new
>> control. :-)
>> Once you have your custom control written, you can use the "Choose
>> Bean" button on the tool bar to place it on your form.
> So this would work?
> -------------------8<-------------------
> Object
> + AbstractSwtWidget (extends org.eclipse.swt.Composite)
> + SingleValueField (uses an org.eclipse.swt.Text)
> + TextField
> + NumberField
> + DateField
> + FormattedField
> + MultiValueField
> + DropDown (uses an org.eclipse.swt.Combo)
> + ListBox (uses an org.eclipse.swt.List )
>> Or read any of several recent threads about how to add your control to
>> the palette.
>> Regards,
>> Dave Orme
Rich Kulp
Re: VE and Custom-Widgets [message #77101 is a reply to message #76911] |
Sun, 16 January 2005 13:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: tomAtLinux.gmx.at
Hi Rich,
do you mean that I could use the structure without deriving my
widget from a composite?
Tom
>>> control. :-)
>> So this would work?
>> Object
>> + TextField
>> + NumberField
>> + DateField
>> + FormattedField
>> + MultiValueField
>>> to the palette.
>>> Regards,
>>> Dave Orme
Re: VE and Custom-Widgets [message #77143 is a reply to message #77101] |
Sun, 16 January 2005 21:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No, I meant in addition. You need the right constructor and you need to
inherit from Composite or Canvas.
Rich Kulp
Re: VE and Custom-Widgets [message #77345 is a reply to message #77331] |
Mon, 17 January 2005 14:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
That's a good question. We've never tested it, so I don't know. Give it
a try, but make sure you have a constructor of
public TextColumn (Table parent, int style)
Tom Schindl wrote:
> Ok. I have now rethought my Object-Structure and use a MVC. One more
> question what when it comes to table-controls. Can I also have a:
> TextColumn (extends TableColumn) and use it in the VE?
> Tom
>> to inherit from Composite or Canvas.
Rich Kulp
Re: VE and Custom-Widgets [message #604454 is a reply to message #76864] |
Fri, 14 January 2005 18:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
>> control. :-)
> So this would work?
> Object
> + TextField
> + NumberField
> + DateField
> + FormattedField
> + MultiValueField
>> the palette.
>> Regards,
>> Dave Orme
Rich Kulp
Re: VE and Custom-Widgets [message #604542 is a reply to message #77101] |
Sun, 16 January 2005 21:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Rich Kulp
Re: VE and Custom-Widgets [message #604595 is a reply to message #77331] |
> Tom
Rich Kulp
FUDForum. Page generated in 0.05034 seconds
