Home » Archived » Test and Performance Tools Platform (TPTP) » Can't create chema valid GLA adapter definition
Can't create chema valid GLA adapter definition [message #76808] Mon, 10 July 2006 16:21 Go to next message
Originally posted by: RGuschin.computel.ru
Hi All.
Problems with creation of GLA adapters.
My actions:
Create new Generic Log Adapter file through wizard.
Expand Configuration node -> Parser node -> CommonBaseEvent node.
Right click on CBE - adding Situation.
Right click on situation - see list of situations (e.g. StartSituation,
ConnectSituation etc.), that's not right cause according to cbe.xsd next
element should be situationType. Also i can't create some attributes.
What I'm dooing wrong? Or may be it's a bug?
Rodion
Re: Can't create chema valid GLA adapter definition [message #77058 is a reply to message #76808] Tue, 11 July 2006 09:58 Go to previous messageGo to next message
Originally posted by: cindyjin.ca.ibm.com
Hi Rodion:
Please look at https://bugs.eclipse.org/bugs/show_bug.cgi?id=77354.
Starting in Hyades 3.2, the situationType is no longer generated by the
GLA editor because it is an abstract class. The list of the situations
(e.g. StartSituation, ConnectSituation etc.) which you see now, are the
actual situation types.
Hope this can help you.
Cindy
Rodion Guschin wrote:
> Hi All.
> My actions:
> Rodion
Re: Can't create chema valid GLA adapter definition [message #77065 is a reply to message #77058] Tue, 11 July 2006 10:53 Go to previous message
Thank's Cindy :) I'm already figure out that :)
Also I changed complex types names for Situation and SituationType in
cbe.xsd to TypeForSituation and TypeForSituationType respectively -
that's (probably) resolve name conflicts between element name and name
of complexType and now I can see missing attributes too :)
Rodion
Cindy Jin wrote:
> Hi Rodion:
> Cindy
>> Hi All.
>> My actions:
>> StartSituation, ConnectSituation etc.), that's not right cause
>> according to cbe.xsd next element should be situationType. Also i
>> Rodion
Previous Topic:Agent Controller and FreeBSD
Next Topic:Where I can get symptom database 2.0 specifications
Current Time: Fri Apr 25 19:20:46 EDT 2025
Powered by FUDForum. Page generated in 0.08290 seconds
