framework extensions question [message #76703] |
Wed, 08 November 2006 01:24  |
Originally posted by: ifedorenko.rogers.com
I am trying to "bundleize" a library that defines few java interfaces
and has a special bytecode transformer that injects implementations of
these interfaces to clients of the library that use them. The bytecode
transformer and injected instances need to share certain state.
ClassLoadingHook looks promising, but... problem is, I can't keep the
interfaces (and classes that implement shared state) inside framework
extension bundle because other bundles cannot depend on a fragment. And
framework seems to disallow "Require-Bundle" for framework extensions,
so I can't keep the interfaces in a separate bundle either.
Is there a way to share classes between framework extension bundle and
other bundles?
Igor Fedorenko
Re: framework extensions question [message #76909 is a reply to message #76703] |
Thu, 09 November 2006 22:06  |
A framework extension can export new packages. But the bundles you are
transforming will need to either import the package you export or use
Require-Bundle: system.bundle to access the package you export from your
system bundle fragment (framework extension).
There are other tricks you can do like exporting the packages from your
framework extension bundle with special matching attributes and have the
bundles that you transform using DynamicImport-Package to access the
package. I recommend using a special matching attribute so that the
DynamicImport-Package is scoped to only the packages you export from
your transforming extension bundle.
<in framework extension bundle manifest>
Export-Package: some.transform.stuff; type="transform"
<in transformed bundle manifest>
Dynamic-Import: *; type="transform"
There are other options that involve calling some internals of the
framework to add dynamic imports "dynamically" to the bundles you
transform by calling
BundleLoader.addDynamicImportPackage(ManifestElement[] packages) This
is one approach the AspectJ project uses in the Equinox incubator.
HTH
Tom.
Igor Fedorenko wrote:
> Hello,
> other bundles?
> Igor Fedorenko
FUDForum. Page generated in 0.02403 seconds
