Home » Newcomers » Newcomers » Not able to run Eclipse
Not able to run Eclipse [message #76524] Fri, 10 June 2005 08:59 Go to next message
Originally posted by: jberthol.statestreet.com
I installe JVM 1.4.2
Eclipse , and I get this log when I try to run it:
Can anyone help?
Thanks in advance...
Jerome
!SESSION Jun 10, 2005
14:44:19.218 ---------------------------------------------
eclipse.buildId=M200503110845
java.version=1.3.1_01
!ENTRY org.eclipse.osgi Jun 10, 2005 14:44:19.218
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(Ec
lipseAdaptor.java:272)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdapto
r.java:253)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemB
undleActivator.java:61)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleConte
xtImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(Bu
ndleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleConte
xtImpl.java:937)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(Sta
rtLevelManager.java:553)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLeve
lManager.java:477)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(S
tartLevelManager.java:273)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartL
evelManager.java:243)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.ja
va:166)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:
216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.osgi Jun 10, 2005 14:44:19.265
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginC
onverterImpl.java:557)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginCo
nverterImpl.java:111)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginC
onverterImpl.java:660)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseB
undleData.java:233)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundl
eData.java:191)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundle
Data.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseB
undleData.java:280)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initial
izeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(De
faultAdaptor.java:451)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(F
ramework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.j
ava:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.j
ava:659)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(Bun
dleContextImpl.java:219)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarte
r.java:800)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStar
ter.java:429)
222)
!ENTRY org.eclipse.osgi Jun 10, 2005 14:44:19.280
!MESSAGE Bundle
initial@reference:file:c:/eclipse/plugins/org.eclipse.core.runtime_3.0.2/
[1] was not resolved.
Re: Not able to run Eclipse [message #76539 is a reply to message #76524] Fri, 10 June 2005 09:33 Go to previous messageGo to next message
you need to run 1.4
as the log indicates, you're running 1.3
run eclipse.exe with the -vm option and specify the path to java.exe or
javaw.exe
/adam
Re: Not able to run Eclipse [message #76555 is a reply to message #76539] Fri, 10 June 2005 09:46 Go to previous message
vote for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=99353
/adam
> you need to run 1.4
> javaw.exe
> /adam
Previous Topic:Simple Browser View
Next Topic:"An error has occured" at startup
Current Time: Mon Apr 28 03:13:12 EDT 2025
Powered by FUDForum. Page generated in 0.07436 seconds
