| Running C++ programs in the console [message #76509] |
Tue, 22 July 2003 14:31  |
Originally posted by: sbh4.duke.edu
Is there an easy way of running C/C++ programs in the Eclipse console window
without switching the parser from Elf to PE Windows? It is important that
the program is run within Eclipse and by double-clicking and runnning
through Windows.
If I choose "Run As", I get a "Launch failed no binaries" error because I
assume that it cannot find the ".exe" file.
If I choose "Run...", I can run it in the console but I have to specify a
configuration (too many steps).
thank you for your time,
Sam
| C++ programs in the console [message #77190 is a reply to message #76727] |
Mon, 28 July 2003 04:27  |
> If you have the right Binary parser(assuming PE) this is how CDT discover
> new binaries, since a file name *.exe is not an indication that this is
> a valid binary. But when you create a project you have the choice
> of choosing the parser not sure why you need to switch again.
The default parser when you make a new C++ project is the Elf parser,
so you do have to manually change it (you have the option of changing it
when you make the project).
My question was how would one run a C++ project in the Eclipse console
WITHOUT using the PE Windows parser or making a Run Configuration with
"Run...".
Here are the facts/problems as I've encountered them:
1) "Run As" doesn't work with the Elf parser (as far as I can tell)
2) If you double click your executable when you have the PE parser enabled,
Eclipse tries to open the file in its text browser and usually will incur an
out of memory error as a result.
3) Running via double-clicking is problematic because the DOS window closes
when the program finishes, making it impossible to see any text output that
is generated.
I just want to be able to run C++ programs as simply as possible without
risking a crash of Eclipse in the process (see #2).
I should explain that I am a CS student working in the Duke CS
department writing documentation on how to use Eclipse as well as writing
some Duke-specific plug-ins (for example, plug-ins that'll download/submit
assignments, etc). We're going to experiment with it as a possible
development platform for intro-level CS classes. An emphasis is placed on
ease-of-use because the students involved would not be computer veterans.
"Run..." is too many steps. You have to click "Run..", then "C/C++ Local",
then "New Configuration", then type in some name for your configuration,
then type in the name of the .exe file. It's rediculous.
Using the PE Windows parser, students will have to switch the parser
manually (remembering to do so everytime), will double-click and crash
Eclipse at least once, and even if they manage to get "Run As" to work, they
still have to click which executable they'd like to run (even if there is
only one) as well as specify a debugger (which as no meaning to them at
all). No good either.
And so I repeat, how would one run a C++ project in the Eclipse console
"Run..."?
I could probably make a hack'ish plug-in that'll auto-generate a run
configuration, but that seems silly (not too mention that it'd probably not
work with future versions of Eclipse).
Sam
FUDForum. Page generated in 0.04576 seconds
