ATL: multiple source pattern elements [message #76489] |
Wed, 12 March 2008 15:51 |
Originally posted by: hdubourg.sodifrance.fr
I'm trying to use the multiple source pattern feature but I'm facing an
error I can't understand.
The minimal ATL transformation I have a problem with is:
rule attribute_class {
from
in1 : kdm!ClassUnit, in2 : kdm!MemberUnit
to
output : uml2!Class (
And here is the error log. It looks like there is only one input local
variable:
SEVERE: A.main() : ??#24 null
SEVERE: local variables = {self=KDMtoUML2 : ASMModule}
SEVERE: local stack = []
SEVERE: A.__exec__() : ??#8 null
SEVERE: local variables = {e=TransientLink {rule = 'attribute_class',
sourceElements = {in1 = input!myClass}, targetElements = {output =
output!<notnamedyet>}, variables = {}}, self=KDMtoUML2 : ASMModule}
SEVERE: A.__applyattribute_class(1 : NTransientLink;) : ??#7 null
SEVERE: local variables = {in1=input!myClass, link=TransientLink {rule
= 'attribute_class', sourceElements = {in1 = input!myClass},
targetElements = {output = output!<notnamedyet>}, variables = {}},
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to
allow continuation after errors).
SEVERE: null
java.lang.RuntimeException
Is there something I'm doing wrong?
Thanks a lot for your help.
Hugues Dubourg
Re: ATL: multiple source pattern elements [message #76535 is a reply to message #76489] |
Wed, 12 March 2008 18:55 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
Do you have
-- @atlcompiler atl2006
at the top of your file?
Frédéric Jouault
Hugues Dubourg a écrit :
> Hello,
> from
> to
> variable:
> {rule = 'attribute_class', sourceElements = {in1 = input!myClass},
> SEVERE: null
> Hugues Dubourg
Re: ATL: multiple source pattern elements [message #76583 is a reply to message #76535] |
Thu, 13 March 2008 08:13 |
I did not...
Since I got the very last version of the ATL plugin I did not think there
could be such an option to write to enable the 2006 features...
Shame on me.
Thanks a lot.
Hugues Dubourg
"Fr
FUDForum. Page generated in 0.03308 seconds
