Re: URI Expression for Image [message #76800 is a reply to message #76672] |
Fri, 23 September 2005 14:26 |
floor,
Have you tried using a local file and then c\testdir\pic.jpg?
Jason Weathersby
BIRT PMC
"floor" <floorflux@hotmail.com> wrote in message
news:dgv6jq$a06$1@news.eclipse.org...
> Since the URI is an expression, not a String, I tried making a report
> parameter called myCompanyLogo, giving it a default value of the URL to my
> image, then setting the image URI to be params["myCompanyLogo"]. I
> thought I had an expression that would've worked, but the image still
> doesn't show up on the report.
> --floor
> news:dgskcc$tl9$1@news.eclipse.org...
>>I am having trouble getting an image from a URL in my reports. I see this
>>is a FAQ in the uncategorized section, but the answer doesn't spell it out
>>well enough for me I guess.
>> Can anyone give me an example of an actual expression that will work for
>> putting an image in a report from a URL? Whatever I put in there either
>> gives me a "failed to evaluate" error or just nothing shows up at all.
>> This is despite the fact that the preview window where I set the URI
>> displays the image, as does the template in Eclipse.
>> Thanks in advance,
>> Floor
Re: URI Expression for Image [message #76929 is a reply to message #76800] |
Fri, 23 September 2005 19:30 |
floor Messages: 93 Registered: July 2009 |
Member |
I cut my image out of the Simple Master Page Header and pasted it into the
Body page and it shows up fine now. It looks like, at least for me, images
in the Simple Master Page don't work but they do in the Body. If I paste it
back into the Master Page it doesn't show up again.
--floor
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:dh13b4$k74$1@news.eclipse.org...
> floor,
> Jason Weathersby
> BIRT PMC
>> my image, then setting the image URI to be params["myCompanyLogo"]. I
>> --floor
>>>this is a FAQ in the uncategorized section, but the answer doesn't spell
>>>it out well enough for me I guess.
>>> Thanks in advance,
>>> Floor
FUDForum. Page generated in 0.03643 seconds
