Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo 0.8.0/0.7.5 Release Notes/Information
Teneo 0.8.0/0.7.5 Release Notes/Information [message #76209] Wed, 21 March 2007 18:29
This post gives a summary of the changes in the latest 0.8.0 release. For the changes in 0.7.5 see
the issue list below.
In the 0.8.0 release of today the following has changed (all for Hibernate):
- Hibernate EntityManager is now supported: this is done through a new datastore HbEntityDataStore.
The current HbDataStore has been made abstract and part of its previous functionality moved to a new
class HbSessionDataStore. So if you have implemented your own datastore inheriting from HbDataStore
then your class should now inherit from HbSessionDataStore. See also here:
http://www.elver.org/hibernate/entitymanager.html.
- New EMap mapping (credits to Jean-Denis Boudreault for contributing a solution here): before the
EMF EMap was mapped as a list (as an EMap is in fact a List) however this had a number of
disadvantages (inefficient, does not work in combination with serialization). Therefore this has
been changed to a true map mapping. As this changes the mapping an option is provided for backward
compatibility: PersistenceOptions.EMAP_AS_TRUE_MAP (default is true), setting this option to false
will result in the 'old' behavior (map emap as a list).
- A number of bugs have been resolved related to handling of multiple inheritance and testcases have
been added. Note that the new multiple inheritance differs from the previous approach if one of the
supertypes has isInterface=true. Teneo chooses one of the supertypes as the one to set as extends in
the hibernate mapping file before also an interface type could be chosen, now Teneo first tries to
find a non-interface supertype.
- A new option has been added to automatically map all lists as a bag in hibernate, in this way the
list index is not present in the database (many times it is not required there). Also an equivalent
option for idbag has been added.
- Jpox support has been upgraded to jpox 1.1.7
Here is the list of issues solved in the 0.8.0 and 0.7.5 release:
Solved in this 0.8.0 release
https://bugs.eclipse.org/bugs/show_bug.cgi?id=153742 - Enhance choosing of real supertype in case of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=169136 - Upgrade to jpox 1.1.7
https://bugs.eclipse.org/bugs/show_bug.cgi?id=176651 - Support for @where hibernate annotation
https://bugs.eclipse.org/bugs/show_bug.cgi?id=176710 - Discriminator column systematically added,
even if super ...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=176722 - Add support for Maps and JTA @MapKey annotation
https://bugs.eclipse.org/bugs/show_bug.cgi?id=176830 - Add an option to disable the list index on
all elist mapping (use bag in hibernate)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=176833 - change relational mapping of EMap
https://bugs.eclipse.org/bugs/show_bug.cgi?id=178311 - Multiple inheritance is not handled correctly
by Teneo
https://bugs.eclipse.org/bugs/show_bug.cgi?id=178453 - Add support for Hibernate EntityManager
https://bugs.eclipse.org/bugs/show_bug.cgi?id=178461 - @MappedSuperClass and MultipleInheritance
does not work t...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=178471 - Multiple inheritance with multi-valued
EReferences in sec...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=178581 - Add option to force an idbag on all list
associations
Solved in this 0.7.5 release
by Teneo
does not work t...
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:JET Null Pointer Exception & XPath Axes
Next Topic:Teneo 0.8.0/0.7.5 Release Notes/Information
Current Time: Mon Apr 28 23:43:18 EDT 2025
Powered by FUDForum. Page generated in 0.06488 seconds
