Home » Eclipse Projects » Remote Application Platform (RAP) » Cannot change textboxes with Selenium for testing purposes
Cannot change textboxes with Selenium for testing purposes [message #76151] Fri, 29 February 2008 13:05 Go to next message
Originally posted by: patrick.f.machado.criticalsoftware.com
Hi all,
I've been trying (with no success) to interact with RAP textboxes with
selenium (with qooxdoo extension), for testing automation purposes.
I've read the http://wiki.eclipse.org/RapUITesting page.
In the end it mentions that selenium type command does not work with
texboxes.
However, I've been investigating a bit on my own on this subject and have
been able to write text into the textfield in two ways (using firebug).
a) Directly writing a value into the input box associated with the rap
text field (and consequently qooxdoo widget) with
document.getElementById(idOfTheInputField).value = 'some value'.
b) Using the qooxdoo accessors to change the corresponding widget
value, with
document.getElementById(idOfTheWidgetDiv).qx_Widget.setValue ('some value')
Both ways show the value changing (visually) in the field, but when some
code accesses the text field (in the RAP level), it remains unchanged.
I've tried (with selenium) to replicate every event in the input field,
but with no success (again the value changes in the input field, but the
upper-level widget at RAP level remains unchanged):
this.selenium.mouseOver(element);
this.selenium.mouseMove(element);
this.selenium.mouseDown(element);
this.selenium.fireEvent(element, "focus");
this.selenium.mouseUp(element);
this.selenium.click(element);
this.selenium.keyDown(element, "s");
this.selenium.keyPress(element, "s");
this.selenium.keyUp(element, "s");
this.selenium.mouseOut(element);
this.selenium.fireEvent(element, "change");
this.selenium.fireEvent(element, "blur");
Does anyone have any insight on what could be going on here?
Re: Cannot change textboxes with Selenium for testing purposes [message #77089 is a reply to message #76151] Thu, 06 March 2008 07:50 Go to previous message
Hi patrick,
as I mentioned on the wiki page the selenium extension for selenium is
just an prototype. Since then the qooxdoo team cared about the testing
problem by organizing their own selenium extension. I think it should be
no problem to replace the one mentioned in the wiki by the one developed
by the qooxdoo team.
Take a look at http://qooxdoo.org/documentation/contrib/simulator for
more informations about testing qooxdoo applications.
Greets
Benny
Patrick Machado wrote:
> Hi all,
> texboxes.
> have been able to write text into the textfield in two ways (using
> firebug).
> value, with
Previous Topic:RAP Development Forum??
Next Topic:Possible bug in HyperLink
Current Time: Wed Jul 02 14:32:23 EDT 2025
Powered by FUDForum. Page generated in 0.03321 seconds
