Home » Language IDEs » Java Development Tools (JDT) » default source folder
default source folder [message #75840] Mon, 14 July 2003 22:06 Go to next message
Originally posted by: jzhou.persistence.com
Does anyone know how to get the name of the default source folder of a Java
project?
Thanks very much,
Jie
Re: default source folder [message #75924 is a reply to message #75840] Tue, 15 July 2003 03:51 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Jie Zhou wrote:
>Hi,
>project?
There is no such thing as a *default* source folder. A Java project
either has 1.n "real" source folders or the project itself is used as
source folder in which case the source is in a IPackageFragment root
(which you don't see in the UI) with the project as its resource.
HTH
Dani
Re: default source folder [message #75935 is a reply to message #75840] Tue, 15 July 2003 04:05 Go to previous messageGo to next message
Jie,
It is not clear to me what you call a 'default' source folder. Source
folders are defined by IClasspathEntries. You can get them using
IJavaProject.getResolvedClasspath(...) and then filter the ones that have
the CPE_SOURCE kind. The path of the IClasspathEntry is the path to the
source folder.
Jerome
"Jie Zhou" <jzhou@persistence.com> wrote in message
news:bevncj$d63$1@eclipse.org...
Java
> project?
> Thanks very much,
> Jie
Re: default source folder [message #76144 is a reply to message #75935] Tue, 15 July 2003 12:50 Go to previous messageGo to next message
Sorry, I should have made it clearer.
I meant the values of the source and output folder used by the New Java
Project Wizard(you can find these values in Window--> preferences-->Java -->
New Project.
Jie
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:bf0cj5$viq$1@eclipse.org...
> Jie,
> source folder.
> Jerome
> > Hi,
> Java
> > project?
> > Thanks very much,
> > Jie
Re: default source folder [message #76317 is a reply to message #75924] Tue, 15 July 2003 15:33 Go to previous messageGo to next message
Thanks. I don't think I have made it clear that I just want to be able to
programmatically get the values of source and output folder that are
specified in the New Java Project prefrence page.
Jie
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bf0bqf$u7q$1@eclipse.org...
> Jie Zhou wrote:
> >Hi,
Java
> >project?
> HTH
> Dani
Re: default source folder [message #76349 is a reply to message #75840] Tue, 15 July 2003 17:00 Go to previous message
Thanks to everyone for trying to help.
I figured this out. I should use the preference store to get the values.
Jie
Java
> project?
> Thanks very much,
> Jie
Previous Topic:Format ICompilationUnit?
Next Topic:org.eclipse.jdt.ui plugin cannot be activated
Current Time: Wed Oct 29 19:01:26 EDT 2025
Powered by FUDForum. Page generated in 0.03341 seconds
