Home » Eclipse Projects » GEF » splitter layout
splitter layout [message #75827] Wed, 16 April 2003 11:58 Go to next message
Originally posted by: melaasar.rational.com
The new palette viewer is on the right side of the editor. Is there a quick
way to get it on the left side?
Maged
Re: splitter layout [message #75844 is a reply to message #75827] Wed, 16 April 2003 12:01 Go to previous messageGo to next message
no, there isn't. We currently do not have the resources to be writing fancy
SWT controls. Such behavior would be useful even without the use of GEF, so
I think this is a JFace issue. (See PartSashContainer, LayoutPart,
SashForm, etc in JFace). These are internal classes, but they are probably
what is required.
"Maged Elaasar" <melaasar@rational.com> wrote in message
news:b7jttd$fgb$1@rogue.oti.com...
> Hello,
quick
> Maged
Re: splitter layout [message #75860 is a reply to message #75844] Wed, 16 April 2003 13:07 Go to previous messageGo to next message
Is there a reason for it to be on the right by default? is it standard?
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b7ju6t$fqn$1@rogue.oti.com...
fancy
so
probably
> what is required.
> > Hello,
> quick
> > Maged
Re: splitter layout [message #75876 is a reply to message #75860] Wed, 16 April 2003 15:26 Go to previous messageGo to next message
Originally posted by: jayuen.alumni.uwaterloo.ca
If you want, you can modify the GraphicalEditorWithPalette class directly.
In the createPartControl method, all you have to do is to reverse the order
that createPaletteViewer(Composite) and createGraphicalViewer(Composite) are
called so that createPaletteViewer is invoked first.
Jason
news:b7k1uc$ivj$1@rogue.oti.com...
> fancy
> so
> probably
> > what is required.
> > > Hello,
> > quick
> > > Maged
Re: splitter layout [message #75892 is a reply to message #75876] Wed, 16 April 2003 15:59 Go to previous message
Do you mean modify directly in the open source file? or my local copy? If
the former, how to do it?
Maged
"Jason Yuen" <jayuen@alumni.uwaterloo.ca> wrote in message
news:b7ka7r$prh$1@rogue.oti.com...
order
are
> Jason
> > fancy
GEF,
> > so
> > probably
> > > what is required.
> > > > Hello,
a
> > > quick
> > > > Maged
Previous Topic:Exceptions in draw2d-standalone
Next Topic:Auto-positioning nodes in the root edit part
Current Time: Fri Oct 31 16:33:33 EDT 2025
Powered by FUDForum. Page generated in 1.28965 seconds
