Re: debugging problem - absent line numbers [message #651 is a reply to message #601] |
Mon, 21 April 2003 15:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: Olivier_Thomann.oti.com
On Mon, 21 Apr 2003 10:40:02 -0400, "ttoyohara"
<ttoyohara@cauldronsolutions.com> wrote:
>I double checked the compiler settings and the Compile with line numbers
>option is set to true.
>any ideas out there? is this a bug with eclipse?
Are you changing the .class file once generated?
If not, please open a bug report against JDT/Core with steps to
reproduce and attach the source file and the corresponding .class file
for the file on which you are trying to set a breakpoint. The .class
file is located in the output folder of the source folder in which
your source file is defined.
Olivier
FUDForum. Page generated in 0.02969 seconds
