Home » Eclipse Projects » Mylyn » Extension points definition
Extension points definition [message #6773] Tue, 03 July 2007 18:22 Go to next message
Lukasz Dywicki is currently offline Lukasz DywickiFriend
Member
Hello everyone, I trying to write some Mylyn extensions but extension
points doesn't specify interfaces or classes. Is it bug? There also no
documentation, it's big problem for me because i can't write code
without Eclipse Wiki.
Do submit or do not submit this problems in bugzilla?
Lukasz
Re: Extension points definition [message #6808 is a reply to message #6773] Wed, 04 July 2007 04:23 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
Hi Lukasz,
Yes, please do submit a bug specifying the extension point that you are
referring to.
http://www.eclipse.org/mylyn/bugs
Also consider singing up for mylyn-integrators@eclipse.org where you can
ask general questions about extension points and documentation.
http://www.eclipse.org/mylyn/community
Mik
> Cheers,
> Lukasz
Re: Extension points definition [message #6821 is a reply to message #6808] Wed, 04 July 2007 21:57 Go to previous message
Member
Mik Kersten napisał(a):
> Hi Lukasz,
> referring to.
Thank you for information, i submit bug
195450: Extension points definitions
[https://bugs.eclipse.org/bugs/show_bug.cgi?id=195450].
When i don't found examples in existing sources (Mylyn integration with
JDT) I'll send queries to our mail lists.
Lucky Luke :)
Re: Extension points definition [message #569757 is a reply to message #6773] Wed, 04 July 2007 04:23 Go to previous message
Mik Kersten is currently offline Mik KerstenFriend
Hi Lukasz,
referring to.
Mik
> Cheers,
> Lukasz
Re: Extension points definition [message #569789 is a reply to message #6808] Wed, 04 July 2007 21:57 Go to previous message
Member
> Hi Lukasz,
> referring to.
Lucky Luke :)
Previous Topic:What happened to the generic web connector?
Next Topic:Changesets and SVN
Current Time: Thu Dec 26 18:16:57 GMT 2024
Powered by FUDForum. Page generated in 0.04294 seconds
