Home » Eclipse Projects » Equinox » How to use the registry with straight osgi?
How to use the registry with straight osgi? [message #75060] Wed, 18 October 2006 09:07 Go to next message
Originally posted by: wbeckwith.gmail.com
Are there any docs or examples that can demonstrate how to do this? I
have a project that I would normally just used the RCP runtime but
because of size contraints, I hoping we can stick to the plugin model by
using osgi and the equinox registry. I'm just at a loss as to how to
get started using them together.
Wb
Re: How to use the registry with straight osgi? [message #75105 is a reply to message #75060] Thu, 19 October 2006 14:53 Go to previous messageGo to next message
Originally posted by: simon.kaegi.cognos.com
For an example of the registry use at just the service level you might take
a look at org.eclipse.equinox.http.registry.
HTH
-Simon
"Wendell Beckwith" <wbeckwith@gmail.com> wrote in message
news:eh58ue$bg6$1@utils.eclipse.org...
> have a project that I would normally just used the RCP runtime but because
> of size contraints, I hoping we can stick to the plugin model by using
> osgi and the equinox registry. I'm just at a loss as to how to get
> Wb
Re: How to use the registry with straight osgi? [message #75305 is a reply to message #75105] Tue, 24 October 2006 11:23 Go to previous messageGo to next message
Hi Wendell,
In addition, if you need just a "simple" extension registry you can look at
the JUnits from the org.eclipse.core.tests.internal.registry.simple package
in the org.eclipse.core.tests.runtime bundle. The "simple" registry can be
run without OSGi, but its functionality is simplified :-). For more details,
see RegistryStrategy, RegistryStrategyOSGI, and EquinoxRegistryStrategy.
To use Eclipse registry without Eclipse, you'll need
org.eclipse.equinox.registry bundle and it's dependents including
org.eclipse.core.jobs. The org.eclipse.equinox.registry, once activated,
creates default registry which can be accessed via
RegistryFactory.getRegistry() or via IExtensionRegistry service. The default
registry is shutdown on the org.eclipse.equinox.registry shutdown.
One other thing you'll need to consider is how you are going to fill the
registry. In Eclipse this is done by processing bundle events from the
update configurator (org.eclipse.update.configurator).
Oleg
"Simon Kaegi" <simon.kaegi@cognos.com> wrote in message
news:eh8hl8$v8g$1@utils.eclipse.org...
> take a look at org.eclipse.equinox.http.registry.
> HTH
> -Simon
>> using osgi and the equinox registry. I'm just at a loss as to how to get
>> Wb
Re: How to use the registry with straight osgi? [message #75521 is a reply to message #75305] Tue, 24 October 2006 22:20 Go to previous message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
Is there a web/wiki page somewhere that I can read about the different
ways to use the registry?
Jeff
Oleg Besedin wrote:
> Hi Wendell,
> Oleg
>> HTH
>> -Simon
>>> Wb
Previous Topic:OSGi does not reload previously installed bundles
Next Topic:Possible bug in resolver
Current Time: Wed Nov 05 11:00:55 EST 2025
Powered by FUDForum. Page generated in 0.03504 seconds
