Home » Archived » XML Schema Definition (XSD) » Letting XSDEcoreBuilder reuse existing EPackages for imported schemas
Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #74579] |
Wed, 11 June 2008 12:56 |
Originally posted by: moritz.eysholdt.de
I'm using the XSDEcoreBuilder to programmatically generate Ecore
packages from XSD files. In my scenario I have a couple of XSD files on
my hard drive and I want to have the derived EPackages in memory. The
XSDs can include/import each other.
The problem is that any XSD can change any time and I have to regenerate
the EPackages while keeping the effort at a minimum.
If one XSD changes, I already manage to reload it's XSDSchema model and
all depending XSDSchema models, so I always have the current XSDSchema
models in memory.
Regenerating the EPackages for all at once works perfectly, but how do I
prevent the XSDEcoreBuilder to regenerate Epackages that have already
been generated and are up to date?
Example:
- there are XSD A and XSD B, A imports B
- there are EPackages A and B generated from the XSDs
- A changes, I reload A and update B's referencingDirectives
- I want to regenerate EPackage A, but NOT EPackage B, since it didn't
change. How to I tell the XSDEcoreBuilder to reuse the existing EPackage B?
First I thought it might be possible by making EPackage B available via
the extendedMetaData's PackageRegistry, but it didn't seem to work out.
Then I noticed that an XSDSchema model's typeDefinition list also
contains all TypeDefinitions of included/imported XSDs... which
surprised me, since I expected to find only the ones that are defined in
that file. And since the XSDEcoreBuilder iterates over that list, this
explains why subpackages are always generated, too.
thanks,
Moritz
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #74597 is a reply to message #74579] |
Wed, 11 June 2008 14:21 |
Moritz,
Comments below.
Moritz Eysholdt wrote:
> on my hard drive and I want to have the derived EPackages in memory.
> The XSDs can include/import each other.
> regenerate the EPackages while keeping the effort at a minimum.
> and all depending XSDSchema models, so I always have the current
> XSDSchema models in memory.
> I prevent the XSDEcoreBuilder to regenerate Epackages that have
> already been generated and are up to date?
I'm not sure how you know which models have changed actually changed...
> Example:
> EPackage B?
By regenerate I guess maybe you mean recreate.
> via the extendedMetaData's PackageRegistry, but it didn't seem to work
> out.
It's also important for the mapping between the schema instance and the
EPackage data to be populated...
> in that file.
The XML Schema specification defines it to be that way...
> And since the XSDEcoreBuilder iterates over that list, this explains
You could let the builder generate all new ones, and if you're sure that
some aren't changed, you could unload the Ecore resources for those,
and let the proxy references resolve to the older version you have
elsewhere...
I'm not sure how you know what's changed and what hasn't though... I
suppose you could keep a builder instance around and keep reusing it
too, though you'd have to clean out the ones you want redone...
> thanks,
> Moritz
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #74615 is a reply to message #74597] |
Wed, 11 June 2008 15:01 |
hi Ed,
thanks for your response. Comments below.
My code runs as plugin within Eclipse and all XML Schemas of concern are
located within projects within the workspace or plugins that projects
depend on.
org.eclipse.core.resources.IWorkspace.addResourceChangeListe ner(IResourceChangeListener)
and
org.eclipse.jdt.core.JavaCore.addElementChangedListener(IEle mentChangedListener)
notify me about all changes.
>> Example:
>> EPackage B?
true.
>> out.
Where can I find that mapping?
>> in that file.
> elsewhere...
But that would mean that the EPackage I already have is recreated
anyway... I want to avoid that, since it is quite time consuming if the
XSD is huge.
Imagine the following:
- I've got Book.xsd, Article.xsd and XHTML.xsd
- Book and Article import XHTML
- I've generated EPackages for all three XSDs
- Book.xsd changes... but I don't want to recreate the EPackage for
XHTML, since it is huge.
Cleaning out the models I have loaded, but wich I want to reload, seems
to work quite good for me so far.
regards,
Moritz
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #74635 is a reply to message #74615] |
Wed, 11 June 2008 17:55 |
Moritz,
Comments below.
> hi Ed,
>>> do I prevent the XSDEcoreBuilder to regenerate Epackages that have
> are located within projects within the workspace or plugins that
> projects depend on.
> and
I see. So you know which physical resources are affected. Of course
any change in a base schema could change all its downstream schemas,
e.g., add something to an attribute group that's used in ten other
complex types in other schemas...
>>> Example:
>>> didn't change. How to I tell the XSDEcoreBuilder to reuse the
> true.
>>> work out.
>> the EPackage data to be populated...
It's the mapping that's populated as you create the Ecore model
instances, i.e, xsdComponentToEModelElementMap.put and calls to map().
>>> defined in that file.
>> that some aren't changed, you could unload the Ecore resources for
>> those, and let the proxy references resolve to the older version you
>> have elsewhere...
> the XSD is huge.
True, but reestablishing the mapping is expensive too and more likely to
be error prone.
Reusing an XSDEcoreBuilder instance, and cleaning out stale mappings
might be better for this kind of thing.
> seems to work quite good for me so far.
Yes, I think that's the best approach for what you've described. Be
sure to look closely at all the maps, including
targetNamespaceToEPackageMap.
> regards,
> Moritz
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #74651 is a reply to message #74635] |
Fri, 13 June 2008 15:57 |
Hi Ed,
thanks again for your hints.
I made it work after all, but it still took some time to figure out to
right approach. I want to describe my solution in case somebody runs
into the same problem one day...
I tried to reuse one singel XSDECoreBuilder instance and to clean out
all stale mappings after each reloading of the modified schemas. This
worked good at the beginning, but I ran into trouble with the following
scenario:
If there are multiple schemas which include (not import) each other,
XSDEcoreBuilder generates one EPackage for them all together. How this
EPackage exactly looks like and which types are included depends on
which schema you start with. I my case, I needed an EPackage for every
single schema file that is supposed to include all types the schema and
its included schemas contain.
So I wanted to end up having multiple Epackages with the same namespace
and xsd-types that have multiple corresponding EClassifiers. Too much
for one XSDECoreBuilder instance to handle.
My solution now looks like this:
Before generating an EPackage, I manually iterate over the schema to
find all XSDIncludes and generate an EPackage for each of them. This way
I ensure an XSDECoreBuilder is generating exactly one EPackage and I end
up maintaining one XSDECoreBuilder instance for every package.
If I now need to recreate an EPackage that depends on EPackages I have
already created, I instantiate a new XSDECoreBuilder for the new
EPackage and initialize the builder's mappings
(targetNamespaceToEPackageMap, xsdComponenentToModelElement etc.) with
the mapping's values of all XSDECoreBuilders that are associater with
the EPackages the new EPackage depends on.
regards,
Moritz
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #74670 is a reply to message #74651] |
Fri, 13 June 2008 16:07 |
Moritz,
Comments below.
> Hi Ed,
Thanks on their behalf!!
> following scenario:
> and its included schemas contain.
Yes, there is a one-to-one mapping between target namespace and EPackage
nsURI. Things will be added to the package as you visit schemas that
define things in that corresponding namespace.
> namespace and xsd-types that have multiple corresponding EClassifiers.
> Too much for one XSDECoreBuilder instance to handle.
Yes, it's not designed to take that approach, because later when these
things are using, the ability to map a given nsURI to just one package
is important...
> way I ensure an XSDECoreBuilder is generating exactly one EPackage and
> I end up maintaining one XSDECoreBuilder instance for every package.
I see. Tricky. Where there's a will, there's a way, usually...
> regards,
> Moritz
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #603060 is a reply to message #74579] |
Ed Merks Messages: 33264 Registered: July 2009 |
Moritz,
Comments below.
> Example:
> EPackage B?
> out.
> in that file.
elsewhere...
> thanks,
> Moritz
Ed Merks
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #603064 is a reply to message #74597] |
Moritz Eysholdt Messages: 161 Registered: July 2009 Location: Kiel, Germany |
hi Ed,
depend on.
and
>> Example:
>> EPackage B?
true.
>> out.
>> in that file.
> elsewhere...
XSD is huge.
regards,
Moritz
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #603068 is a reply to message #74615] |
Moritz,
Comments below.
> hi Ed,
> projects depend on.
> and
>>> Example:
> true.
>>> work out.
>> have elsewhere...
> the XSD is huge.
be error prone.
> regards,
> Moritz
Ed Merks
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #603074 is a reply to message #74635] |
Hi Ed,
scenario:
regards,
Moritz
Re: Letting XSDEcoreBuilder reuse existing EPackages for imported schemas [message #603079 is a reply to message #74651] |
Moritz,
Comments below.
> Hi Ed,
> following scenario:
is important...
> regards,
> Moritz
Ed Merks
Current Time: Wed Feb 05 06:45:30 GMT 2025
Powered by FUDForum. Page generated in 0.03968 seconds
