org.eclipse.jdt_2.1.0/plugin.xml 0 bytes [message #74500] |
Sat, 14 June 2003 11:27  |
Originally posted by: sublime78ska.attbi.com
I have eclipse-SDK-2.1-linux-gtk installed in my home directory on Mandrake
Linux 9.1.
I start it with this:
/home/phil/eclipse/eclipse -data /home/phil/Arbeit/eclipse-workspace -vm
/usr/java/j2re1.4.1_02/bin/java
and I get this error: "Problems during startup. Check the ".log" file in
the ".metadata" directory of your workspace.
It appears that the error is because
/eclipse/plugins/org.eclipse.jdt_2.1.0/plugin.xml is zero bytes. I looked
in the archive file I downloaeded, and although it says it's 152 bytes it's
empty too.
Here's the top of the log file:
!SESSION Jun 14, 2003 10:44:26.756 -----------------------------------------
java.version=1.4.1_02
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -data
/home/phil/Arbeit/eclipse-workspace -install file:/home/phil/eclipse/
!ENTRY org.eclipse.core.runtime 2 1 Jun 14, 2003 10:44:26.757
!MESSAGE Problems encountered loading the plug-in registry.
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Jun 14, 2003 10:44:26.757
!MESSAGE Parsing error in "plugin.xml" [line -1, column -1]: "Premature end
of file.".
!STACK 0
org.xml.sax.SAXParseException: Premature end of file.
and here's the middle of the file:
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Jun 14, 2003 10:44:26.759
!MESSAGE Error while processing
" file:/home/phil/eclipse/plugins/org.eclipse.jdt_2.1.0/plugin .xml ".
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0 Jun 14, 2003 10:44:31.396
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
This file is 0 bytes.
Thanks for your help!
Phil
Re: org.eclipse.jdt_2.1.0/plugin.xml 0 bytes [message #74641 is a reply to message #74500] |
Sat, 14 June 2003 21:00  |
OK I found the plugin.xml file here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jdt/plu gin.xml
so I got past this error. Unfortunately, I still have problems but I'll
work on them before asking for help.
> Mandrake Linux 9.1.
> looked in the archive file I downloaeded, and although it says it's 152
> bytes it's empty too.
> end of file.".
> !STACK 0
> !STACK
> Phil
Phil
FUDForum. Page generated in 0.02827 seconds
