Home » Archived » BIRT » Feature 'Title' not found. (test.chart, 213, 14)
Feature 'Title' not found. (test.chart, 213, 14) [message #74328] |
Thu, 15 September 2005 08:02 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: thmwg.web.de
Hello everybody,
IŽm designed a Chart within BIRT. In "Preview" the chart was shown
correctly. Then I copied the chart to
"JBOSS/server/delopy/birt-viewer.war/MyReport.rptdesign and started the
server. After trying to open the report I got followed error. Any
suggestions to solve this problem.
Thanks.
Thomas
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'Title' not
09:58:46,799 INFO [STDOUT] at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeatu re(XMLHandler.java:1168)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeatu re(XMLHandler.java:1138)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1099)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:448)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:431)
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.startElement(SAXWr apper.java:75)
org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
javax.xml.parsers.SAXParser.parse(SAXParser.java:345)
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:129)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:155)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:895)
org.eclipse.birt.chart.model.impl.SerializerImpl.fromXml(Ser ializerImpl.java:377)
org.eclipse.birt.chart.reportitem.ChartReportItemImpl.deseri alize(ChartReportItemImpl.java:215)
org.eclipse.birt.report.model.extension.PeerExtensibilityPro vider.initializeReportItem(PeerExtensibilityProvider.java:37 7)
org.eclipse.birt.report.model.elements.ExtendedItem.initiali zeReportItem(ExtendedItem.java:273)
org.eclipse.birt.report.model.api.ExtendedItemHandle.loadExt endedElement(ExtendedItemHandle.java:99)
org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl.s etModelObject(ChartReportItemQueryImpl.java:60)
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$Q ueryBuilderVisitor.visitExtendedItem(ReportQueryBuilder.java :325)
org.eclipse.birt.report.engine.ir.ExtendedItemDesign.accept( ExtendedItemDesign.java:30)
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$Q ueryBuilderVisitor.buildQuery(ReportQueryBuilder.java:191)
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.b uild(ReportQueryBuilder.java:123)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.prepar e(DteDataEngine.java:173)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:132)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:159)
org.eclipse.birt.report.viewer.aggregation.layout.EngineFrag ment.doService(Unknown
Source)
org.eclipse.birt.report.viewer.aggregation.BaseFragment.serv ice(Unknown
Source)
org.eclipse.birt.report.viewer.servlets.ViewerServlet.doPost (Unknown
Source)
org.eclipse.birt.report.viewer.servlets.ViewerServlet.doGet( Unknown Source)
javax.servlet.http.HttpServlet.service(HttpServlet.java:697)
javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:81)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:202)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
org.jboss.web.tomcat.security.CustomPrincipalValve.invoke(Cu stomPrincipalValve.java:39)
09:58:46,809 INFO [STDOUT] at
org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:153)
org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:59)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:856)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:744)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)
org.apache.tomcat.util.net.MasterSlaveWorkerThread.run(Maste rSlaveWorkerThread.java:112)
09:58:46,809 INFO [STDOUT] at java.lang.Thread.run(Thread.java:534)
Re: Feature 'Title' not found. (test.chart, 213, 14) [message #74897 is a reply to message #74328] |
Fri, 16 September 2005 14:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hello together,
I solved the problem. In the xml-file "new_report.rptdesign" was a node
called "<title>" which cannot be parsed and thatswhy a exception was
thrown. I deleted this node and then it runs fine.
Greetings
Thomas
Current Time: Wed Jul 17 18:47:14 GMT 2024
Powered by FUDForum. Page generated in 0.03202 seconds
