Open java source created by Netbeans GUI form editor [message #74031] |
Tue, 07 December 2004 12:49  |
Does any one on the newsgroup have the experiecne to open a GUI Java
source created by Netbeans or other IDE GUI form editors? I tried this
with Eclipse VE but the result is not very good. [Maybe due to the
variable naming convenxction like ivj....]
Is there any discussion threads or online documents available on the web?
Jack
Re: Open java source created by Netbeans GUI form editor [message #74321 is a reply to message #74197] |
Wed, 08 December 2004 12:05  |
Jeff,
Thanks for the help. I think some migration steps are required.
Hmm, it seems some OTI folks are monitoring the discssions here. It
sounds good.
Best Regards
Jack
Jeff Myers wrote:
> Hi Jack,
> There are two main problems importing code from Netbeans into the VE.
> 1) There's the implicit use of the content pane in JFrames - Netbeans
> uses code like myJFrame.getContentPane().add(aButton); The VE does not
> currently support the getContentPane() call. To make this code work
> with the VE, add a JPanel to your class and change all references to
> getContentPane() to add to this panel directly. Then use the
> setContentPane() method on the JFrame to set your new panel as the
> contentPane. See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=48552
> 2) GridBagConstraints objects are reused for every component in a
> layout. The VE gets confused by this - you'll need to change your code
> to have a separate GridBagConstraint object for each component on the
> layout. See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=76178
> For a slightly outdated overview of the source code pattern recognized
> by the VE, you can read this article:
> http://www-106.ibm.com/developerworks/websphere/library/tech articles/0303_winchester/winchester.html
> We're always trying to improve the ability of the VE to parse other code
> patterns, but it's often not the highest priority feature.
> Hope this helps,
> - Jeff
> Jack Chi wrote:
>> Thanks
>> Jack
Re: Open java source created by Netbeans GUI form editor [message #603757 is a reply to message #74031] |
Tue, 07 December 2004 16:51  |
Hi Jack,
Hope this helps,
- Jeff
Jack Chi wrote:
> Thanks
> Jack
Re: Open java source created by Netbeans GUI form editor [message #603789 is a reply to message #74197] |
Jeff,
sounds good.
Best Regards
Jack
Jeff Myers wrote:
> Hi Jack,
> Hope this helps,
> - Jeff
> Jack Chi wrote:
>> Thanks
>> Jack
FUDForum. Page generated in 0.06441 seconds
