Home » Archived » BIRT » Printing BIRT report out it to CSV
Printing BIRT report out it to CSV [message #73960] Wed, 14 September 2005 12:55 Go to next message
Originally posted by: sai.yelamanchili.gmail.com
How can I printout a BIR report to CSV. Can I do this ?
Sai
Re: Printing BIRT report out it to CSV [message #73996 is a reply to message #73960] Wed, 14 September 2005 13:58 Go to previous messageGo to next message
hi Sai
Not sure if birt supports output to that type, just PDF and HTML as far
as I know.
Howver, take a look at the following birt 2.0 feature specifications at:
http://eclipse.org/birt/wiki/index.php?n=BPS.BPS
I looked around and possibly BPS32 might be where you might want to add
comments..not sure.
Sai Yelamanchili wrote:
> Hi
> Thanks
> Sai
Re: Printing BIRT report out it to CSV [message #74780 is a reply to message #73996] Fri, 16 September 2005 06:38 Go to previous messageGo to next message
This is a high priority feature for my work as well.
Mike Boyersmith wrote:
> hi Sai
> as I know.
> comments..not sure.
>> Hi
>> Thanks
>> Sai
Re: Printing BIRT report out it to CSV [message #74866 is a reply to message #73960] Fri, 16 September 2005 09:34 Go to previous message
If you need a quick workaround you could open a file in the report's
initialize() method and close it in the report's afterFactory() method.
Then on the Table's onRow() method - write a csv line to the file using
row["column-name1"] + "," + row["column-name2"] + "," +
row["column-name3"]...
you could do this in the main report - but it would always create a csv
file - or you could write another "csv driver" report that does this when
the user clicks on a "Download to CSV" link in the main report - which
runs the csv driver report and then points the browser at the resulting
csv file
Previous Topic:Running external apps
Next Topic:Feature 'Title' not found. (test.chart, 213, 14)
Current Time: Sat Oct 25 15:25:25 EDT 2025
Powered by FUDForum. Page generated in 0.04615 seconds
