Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #73916 is a reply to message #73807] |
Mon, 12 June 2006 19:05 |
Linda Chan Messages: 845 Registered: July 2009 |
The DTP modelbase plugins, as included in the BIRT N20060530 build, are
indeed incomplete. The BIRT build should not have included these DTP
modelbase plugins in the first place.
They are no longer included since the BIRT 20060602 build.
A work-around is to manually remove all the DTP modelbase plugins from
your installation, since they are not used by BIRT.
Or, if you want to get the complete DTP plugins, download the version
distributed by DTP download page or the Callisto update site.
Linda
John O'Shea wrote:
> I've installed the BIRT 2.1.0 zip (1) for TPTP 4.2.0 (as recommended
> at bottom of (2)) to enable reporting from the <tptp:publication> ant
> task and I noticed that on startup the Error Log is reporting a number
> of errors installing BIRT bundles. For example:
> Error
> Mon Jun 12 12:09:49 BST 2006
> Plugin does not have a valid version:
> plugins/org.eclipse.datatools.modelbase.sql_0.9.0.200605101/
> Error
> plugins/org.eclipse.datatools.modelbase.sql.xml.query_0.9.0. 200605101/
> Presumably these plugins are coming from DTP, and looking at the
> offending plugin folders, they do seem to be missing Manifest files.
> Has anyone else noticed this? Should TPTP be using a revised BIRT/DTP
> distribution?
> (1)
http://www.eclipse.org/downloads/download.php?file=/birt/dow nloads/drops/N-R1-N20060530-200605300632/birt-report-framewo rk-N20060530.zip
> (2)
http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.2.0- 200605251528B.html
FUDForum. Page generated in 0.03118 seconds
