Home » Modeling » BPEL Designer » Using BPEL model
Using BPEL model [message #6643] Tue, 23 January 2007 16:02 Go to next message
Originally posted by: ssinha4.covansys.com
Hi ,
I have emf model based on xml schema and working editor using that I can
save the instances of schema and I want to convert XML instances to BPEL
process using org.eclipse.bpel.model. Is it possible to use
org.eclipse.bpel.model API in Java client program? I tried to explore the
org.eclipse.bpel.model jar files but it seems model code has not been
exposed in plugin.
Sanjeev Sinha
Re: Using BPEL model [message #6661 is a reply to message #6643] Tue, 23 January 2007 17:53 Go to previous message
You can use the EMF model anywhere, you should need to have the right
jar files in the classpath. There are details on how to do this in the
EMF projects.
You would need the model jar files from the org.eclipse.bpel.model
plugin plus at the very least the EMF classes. You would most likely
need the XSD and WSDL emf models as well.
Sanjeev Sinha wrote:
> Hi ,
> the org.eclipse.bpel.model jar files but it seems model code has not
> been exposed in plugin.
> Regards
> Sanjeev Sinha
Previous Topic:BPEL Annotations/Extensions
Next Topic:Map an External Model to BPEL Model like uiextensionmodel?
Current Time: Fri Apr 25 19:00:58 EDT 2025
Powered by FUDForum. Page generated in 0.03607 seconds
