Home » Archived » XML Schema Definition (XSD) » Cannot set content of XSD Particle
Cannot set content of XSD Particle [message #73673] Thu, 21 February 2008 19:39 Go to next message
Originally posted by: mmendonca.galdosinc.com
I am using the eclipse XSD API to rewrite schemas. I am trying to add
particles to a model group. The added particles should be based on an
existing particle in the model group, but with a different element
content. Hence, I clone a particle, using
particle.cloneConcreteComponent(true, true). I set an existing element as
the content of this particle. However, when I do this, I get the following
exception:
org.eclipse.xsd.impl.XSDConcreteComponentImpl.forceNiceRemov eChild(XSDConcreteComponentImpl.java:1696)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.niceRemoveChil d(XSDConcreteComponentImpl.java:1609)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.orphanContent( XSDConcreteComponentImpl.java:1449)
org.eclipse.xsd.impl.XSDParticleImpl.orphanContent(XSDPartic leImpl.java:715)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1199)
org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch (NotificationImpl.java:1030)
org.eclipse.xsd.impl.XSDParticleImpl.setContent(XSDParticleI mpl.java:324)
com.galdosinc.smt.rewriter.SchemaRewriter.processModelGroup( SchemaRewriter.java:462)
com.galdosinc.smt.rewriter.SchemaRewriter.processElementGrou p(SchemaRewriter.java:586)
com.galdosinc.smt.rewriter.SchemaRewriter.processElementGrou pList(SchemaRewriter.java:411)
com.galdosinc.smt.rewriter.SchemaRewriter.processSchema(Sche maRewriter.java:275)
com.galdosinc.smt.rewriter.SchemaRewriter.rewriteSchema(Sche maRewriter.java:202)
com.galdosinc.smt.rewriter.SchemaRewriter.main(SchemaRewrite r.java:104)
The following is an example of my code:
XSDParticle particleClone =
(XSDParticle)particle.cloneConcreteComponent(true, true);
particleClone.setContent(modelGrpSubstitutableElement); //This is where
the error occurs
Am I using the cloneConcreteComponent method correctly. Is there something
else I need to call after particle.setContent?
Also, are there any code-examples on using the Eclipse XSD API to edit
schemas?
Any help is greatly appreciated!
Michael
Re: Cannot set content of XSD Particle [message #73692 is a reply to message #73673] Thu, 21 February 2008 21:04 Go to previous message
Michael,
I don't think you want to share the DOM with another component already
using that DOM, i.e., false for the second argument would be better.
I'm not sure why you'd clone at all if you are going to set the content
anyway, i.e, why not just create a new particle. XSDPrototypicalSchema
shows all kinds of examples for how to create things...
Michael wrote:
> as the content of this particle. However, when I do this, I get the
> following exception:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> where the error occurs
> something else I need to call after particle.setContent?
> schemas?
> Michael
Re: Cannot set content of XSD Particle [message #602839 is a reply to message #73673] Thu, 21 February 2008 21:04 Go to previous message
Michael,
Michael wrote:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> schemas?
> Michael
Previous Topic:Cannot set content of XSD Particle
Next Topic:How to reference/use the XSD Ecore model
Current Time: Wed Apr 16 01:40:23 EDT 2025
Powered by FUDForum. Page generated in 0.05054 seconds
