| Possible bug in generated DocumentProvider::saveDocumentToFile method? [message #6605] |
Fri, 04 August 2006 09:53  |
Originally posted by: lynchjack.hotmail.com
I'm seeing an issue where I
- create diagram A via New File wizard and close it
- create another diagram B via New File wizard
- attempt to open A again and get a NullPointerException because the content
of the diagram file has been overwritten (set to empyy) during the creation
of B.
Investigating, I find that the same TransactionalEditingDomain and
ResourceSet are in use for both diagrams.. In the generated
saveDocumentToFile method it saves the diagram file and then iterates
through all resources in the ResourcetSet, saving them if they're not the
diagram one. I guess this is the "save model(s)" part. It seems that A is
still there, with its diagramResource not loaded, but the modelResouce
loaded. Calling save on the non-loaded diagramResource is what is causing
the overwrite (a call to resource.isLoaded() is probably needed before
calling save).
My question is, should *all* the resources in the set be saved here? In
theory the diagram could be backed by multiple resources, so I can see why
that code is there. But what if some of the resources are being edited by
another edtor?
Perhaps my real problem is having the same EditingDomain and ResourceSet
being used by multiple editors?
Jack
| Re: Possible bug in generated DocumentProvider::saveDocumentToFile method? [message #6623 is a reply to message #6605] |
Fri, 04 August 2006 10:15  |
Found what causes the problem, take the mindmap example and add an extension
of type
org.eclipse.emf.transaction.editingDomains
with values
org.eclipse.gmf.examples.mindmap.diagram.EditingDomain
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory
Then create A and close. Create B. Attempt to open A.
To be honest, I can't remember why I contributed the editing domain in the
first place :-(
Jack
"Jack Lynch" <lynchjack@hotmail.com> wrote in message
news:eavjid$viq$1@utils.eclipse.org...
> content of the diagram file has been overwritten (set to empyy) during the
> creation of B.
> is still there, with its diagramResource not loaded, but the modelResouce
> calling save).
> by another edtor?
> Jack
FUDForum. Page generated in 0.02963 seconds
