Generate Java classes from XSD [message #73269] |
Wed, 31 October 2007 03:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: akfriebel.yahoo.com.au
I am new to tools such as JAXB, so please forgive me if the answer is
simple.
I am trying to generate java classes from an XSD document. I installed a
plugin for JAXB (version 2.1). This generated my classes, but it
generated '@Xml*' code: eg:
@XmlAccessorType
@XmlEnum
@XmlType
etc
These do not work with java 1.6, and I don't want to have to revert back
to java 1.5.
I am essentially trying to find an easier way to deal with xml rather than
using SAX and DOM directly. I don't really want to have to worry about
the underlying XML structure. I wish to just pump my data into the java
objects, and then marshal the java data into the xml file that I require.
With the objects bound using the xsd document, I know this is achievable
(and many out there are probably doing this already).
I have a simple project I am working on so I can get my knowledge up to
speed. Having the right plugin would be helpful. Can somebody please
point me in the right direction.
Thankyou.
Re: Generate Java classes from XSD [message #73287 is a reply to message #73269] |
Wed, 31 October 2007 12:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------060101070406050506090006
Andrew,
Comments below.
> simple.
> installed a plugin for JAXB (version 2.1). This generated my classes,
> but it generated '@Xml*' code: eg:
> @XmlAccessorType
> @XmlEnum
> @XmlType
> etc
> back to java 1.5.
I can't provide JAXB help since I've never used it
> than using SAX and DOM directly. I don't really want to have to worry
> about the underlying XML structure. I wish to just pump my data into
> the java objects, and then marshal the java data into the xml file
> that I require. With the objects bound using the xsd document, I know
> this is achievable (and many out there are probably doing this already).
> to speed. Having the right plugin would be helpful. Can somebody
> please point me in the right direction.
I'd suggest trying this tutorial but with your schema as input instead
of the library example.
< http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html>
If you invoke "Generate Test Code", in the *.tests projects there will
be an XyzExample.java you can start to modify to see how to serialize an
instance you create programmatically.
This article will be useful as well:
Binding XML to Java
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
> Thankyou.
<html>
<head>
http-equiv="Content-Type">
</head>
Andrew,<br>
<br>
Comments below.<br>
<br>
Andrew wrote:
<blockquote
cite="mid:2b77282391cae1f3639f2a06236b75a5$1@www.eclipse.org"
type="cite">I am new to tools such as JAXB, so please forgive me if
the answer is simple.
<br>
<br>
Re: Generate Java classes from XSD [message #73321 is a reply to message #73287] |
Thu, 01 November 2007 02:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ed,
Sorry about the last post, my typing got ahead of myself.
Thankyou for your response. I will review the links you provided and see
how I go.
Re: Generate Java classes from XSD [message #73339 is a reply to message #73287] |
Thu, 01 November 2007 03:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed,
EMF is very powerful. A lot to digest. Thanks for your input. I am
still to read your article on binding - my head is still spinning from
what EMF can do, and what it can be used for. I appreciate your time to
respond.
I did also get to the bottom of my initial problem. It was a lot simpler
than what I thought. I am using the 1.6 JRE, yet my complier compliance
level (Project properties -> Java Compiler) was only set to 1.4. Good on
me - don't I feel like a goose. When I chnage it to 1.5 or 1.6, my errors
that I reported are resolved.
Thought it was useful to post this in case others were watching the
posting.
Andrew
Re: Generate Java classes from XSD [message #602689 is a reply to message #73269] |
Wed, 31 October 2007 12:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33178 Registered: July 2009 |
Andrew,
Comments below.
> simple.
> @XmlAccessorType
> @XmlEnum
> @XmlType
> etc
> back to java 1.5.
Binding XML to Java
> Thankyou.
<html>
<head>
</head>
Andrew,<br>
<br>
Comments below.<br>
<br>
Andrew wrote:
<blockquote
<br>
<br>
Ed Merks
FUDForum. Page generated in 0.04214 seconds
