Home » Archived » XML Schema Definition (XSD) » Proper way to get the default value for an attribute
Re: Proper way to get the default value for an attribute [message #73089 is a reply to message #73071] |
Fri, 28 September 2007 15:26 |
Rich,
It's kind of nasty how this works. A global attribute attribute
declaration can directly have a default and then a reference to that
attribute can have a different default and the specification defines
that the attribute use carries the default (which is different for the
element case were the element always carries the default, not the
particle). So you need to be pretty careful about keeping track of the
actual attribute use because once you've resolved to a global attribute
declaration whose container is the XSDSchema, the default that applies
there may not be the right one. So as a general rule of thumb, it's
best to keep your hands on the attribute use, otherwise you'll need to
work your way back to it via the eContainer()/getContainer() method (and
this isn't possible if you've gone so far as to resolve the attribute
reference to the global attribute)...
Richard Gregory wrote:
> I have this code to get the default value that works fine for an
> XSDElementDeclaration:
> XSDElementDeclaration.getLexicalValue();
> However, when I call get XSDAttributeDeclaration.getLexicalValue(), it
> always returns null, for example with this XSD:
> <xsd:complexType name="HasDefault">
> <xsd:sequence>
> <xsd:element minOccurs="0" name="field1" type="xsd:string"
> default="some default value" />
> </xsd:sequence>
> <xsd:attribute name="attr" type="xsd:int" default="123"/>
> </xsd:complexType>
> I see from introspecting the XSDAttributeDeclaration at runtime that
> the default value is in
> XSDAttributeDeclaration.eContainer.lexicalValue and in .value, where
> eContainer is an XSDAttributeUse.
> So I can write code to get it from there, but is that the right way? I
> would expect a more direct way.
> Rich
Re: Proper way to get the default value for an attribute [message #73106 is a reply to message #73089] |
Sat, 29 September 2007 03:48 |
Richard Gregory Messages: 13 Registered: July 2009 |
Junior Member |
Thanks Ed! I see where I was going wrong.
Ed Merks wrote:
> Rich,
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> Thanks,
>> Rich
Re: Proper way to get the default value for an attribute [message #602639 is a reply to message #73071] |
Ed Merks Messages: 33183 Registered: July 2009 |
Rich,
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> Rich
Ed Merks
Re: Proper way to get the default value for an attribute [message #602645 is a reply to message #73089] |
Junior Member |
Ed Merks wrote:
> Rich,
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> Thanks,
>> Rich
Current Time: Thu Jul 18 05:24:18 GMT 2024
Powered by FUDForum. Page generated in 0.04827 seconds
