Code Assist does not show Templates [message #6548] |
Tue, 18 January 2005 22:27 |
Originally posted by: jeff.sisna.com
I'm trying to use the template functions in ecplise. I am running the
latest 3.01 stable build on Mac OS X. When I press CRTL-Space or
Apple-Space (both do the same thing) the templates defined in
Preferences->Java->Editor->Templates do not appear. I have tested with a
windows system and Eclipse 3.01 and have the saem result. I have also
tried for example typing 'for 'in a method and then pressing CRTL-Space
and even then it does not show the different for templates as an option.
What am i doing wrong.
Jeff
Re: Code Assist does not show Templates [message #8113 is a reply to message #8082] |
Wed, 19 January 2005 15:50 |
Originally posted by: daniel.megert.gmx.net
Tom Eicher wrote:
> This should work - have you modified the template preferences (note
> that you can disable the templates on the preference page)? Does it
> work with a fresh install?
Does normal code completion work?
Dani
> -tom
>> the latest 3.01 stable build on Mac OS X. When I press CRTL-Space or
>> with a windows system and Eclipse 3.01 and have the saem result. I
>> have also tried for example typing 'for 'in a method and then
>> pressing CRTL-Space and even then it does not show the different for
>> templates as an option. What am i doing wrong.
>> Jeff
FUDForum. Page generated in 0.06948 seconds
