Build Error [message #72779] |
Thu, 05 June 2003 13:28 |
Originally posted by: xlzhao.connect.carleton.ca
I tried building the example helloworld makefile with both cygwin and
MinGW.
I even tried renaming the mingw32-make to make but nothing works so far
and I've tried changing my build path to MinGW/bin and cygwin/bin
I still have a building error.
Build Error
(Exec error:Launching failed)
Is there anything else I can try?
Re: Build Error [message #72923 is a reply to message #72779] |
Thu, 05 June 2003 20:26 |
Originally posted by: vikram.anand.itcinfotech.com
Put the the folder D:\\MinGW\\bin in the Path as the environment variable.
Restart Eclipse.
I think it should work.
Lucie Zhao wrote:
> Hi
> MinGW.
> and I\'ve tried changing my build path to MinGW/bin and cygwin/bin
> Build Error
> Thanks
Re: Build Error [message #72989 is a reply to message #72923] |
Fri, 06 June 2003 13:11 |
Thanks for ur suggestion but it still didn't work
Is the double \\ a typo or should it be like that?
I tried both C:\MinGW\bin and C:\\MinGW\\bin.
Neither worked.
Lucie
> Restart Eclipse.
> Lucie Zhao wrote:
> > Hi
> > MinGW.
> > Build Error
> > Thanks
FUDForum. Page generated in 0.02616 seconds
