utf-8 [message #72500] |
Wed, 04 June 2008 11:46 |
Originally posted by: leonardo.saracini.tiscali.it
I'm developping in utf8 in a simple mode:
I store in DB using utf8 table with utf8 connection and write in editor
direct in utf8.
So my web page are in utf-8 and I have not trouble with realize a multi
language site.
Im using a Opensource esitor Notepad++ on windows plus my server ubuntu to
simulate on my local lan my web sites.
Notepad++ report the type of text codeding of a file and I can change UTF8
to ISO and ISO to UTF8 with no problem.
If I use PDT can I write in utf8 using your editor? Can I changhe from
ISO to UTF8 or UTF8 to ISO?
Leonardo
Re: utf-8 [message #72524 is a reply to message #72500] |
Wed, 04 June 2008 15:31 |
Originally posted by: codeslave.ca.ibm.com
Right-click a project or file, and select the Properties then the
Resource tab. You can manually set the encoding for the project and its
children, or just a single file.
> direct in utf8.
> language site.
> to simulate on my local lan my web sites.
> UTF8 to ISO and ISO to UTF8 with no problem.
> Best regards,
> Leonardo
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: utf-8 [message #72542 is a reply to message #72524] |
Mon, 09 June 2008 08:20 |
Originally posted by: spam.networks.fi
Here is interesting point: is php5 already fully compatible with utf8 so
you can really code it using utf8? Does interpreter completely
understand utf8 ?
>> editor direct in utf8.
>> multi language site.
>> ubuntu to simulate on my local lan my web sites.
>> from ISO to UTF8 or UTF8 to ISO?
>> Best regards,
>> Leonardo
Re: utf-8 [message #72833 is a reply to message #72542] |
Wed, 11 June 2008 11:58 |
> understand utf8 ?
>> its children, or just a single file.
>>> Best regards,
>>> Leonardo
I use UTF-8 for all my projects and output encoding of sites I make is
UTF-8 too. Not a single issue regarding encodings. However there are
certain quirks and "hidden" things that you have to know to use UTF-8 or
at least I do not know them until I start using this encoding.
FUDForum. Page generated in 0.04325 seconds
