Re: MetaCoder RC2 plug-in available for download [message #6526 is a reply to message #6508] |
Thu, 11 July 2002 06:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andrew V. Zavtrakov![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=gro%40bifit.com) Messages: 2 Registered: July 2009 |
Junior Member |
It's a really great project, thanks.
Eclipse lacks XML support, and it's very noisy - no coloring, no validation
etc, so maybe you can release XML/XSLT Eclipse support ( already released in
MetaCoder plugin) as a standalone plugin?
"Tayo" <tayo@btclick.com> wrote in message
news:agj6iv$uh4$1@rogue.oti.com...
> The MetaCoder Development Environment
> o A Choice of Template Languages XSLT, Java / W3C interface, Java / JDom
> o Syntax Highlighting Editors for XSL, XML
> o Context Sensitive Code Assist in both the XML and XSLT editors
> o Line Directed Error Checking
> o Code Generated directly into a test environment for final validation
> o Direct Database Meta Data to XML import using a built in XSLT extension
> The Test Environment
> o Execute Transforms to Console, Errors shown in Task List
> o Generate multipule output files
> o Auto Compile generated Java checking for compile time errors, Errors
shown
> in Task List
> Deploy MetaCode
> o Package the MetaCode as a Wizard that can be invoked from within your
IDE
> Download Plug-in / Documentation / Samples
> http://metacoder.info
Re: MetaCoder RC2 plug-in available for download [message #567510 is a reply to message #6508] |
Thu, 11 July 2002 06:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Junior Member |
shown
> in Task List
> Deploy MetaCode
IDE
FUDForum. Page generated in 0.02894 seconds
