Home » Archived » XML Schema Definition (XSD) » Schema Merging
Re: Schema Merging [message #72185 is a reply to message #72167] |
Thu, 26 April 2007 16:01 |
--------------000406050004050800060305
Klaus,
I don't understand how it got past *this *guard:
if (getElement() != null && (childElement == null ||
childElement.getParentNode() == null))
if (childElement != null && *childElement.getOwnerDocument() !=
getElement().getOwnerDocument()*)
xsdConcreteComponent.setElement(null);
childElement = null;
handleElementForAdopt(eReference, xsdConcreteComponent);
xsdConcreteComponent.updateElement();
I'd need to see the problem in action...
To preserve all your DOM content (e.g., documentation, appinfo and
non-schema namespace attributes), you'd likely be better off to clone
the DOM nodes themselves and add them directly to the new schema's DOM.
(And you'd probably be better off doing an addAll instead of adding one
at a time.) Using XSDConcreteComponent.cloneConcreteComponent(true,
false) and adding a clone might be a way to avoid whatever problem you
are seeing...
Klaus Schaefers wrote:
> I'm trying to generate a new Schema based on an old Schema that
> conatins all included / imported schemas. E.g. a includes B & C then
> the new schema D schould contain all types of A, B and C.
> I have tried it like this:
> XSDSchema newSchema = XSDSchemaBuildingTools.getBlankSchema(factory,...);
> list complexTypes = getAllComplexTypesRecursivly.
> for(ComplexType type: complexTypes)
> newSchema.getContents().add(type).
> When I try to sreialize the new Schema with Xerces i got the following
> error:
> org.w3c.dom.DOMException: WRONG_DOCUMENT_ERR: A node is used in a
> different document than the one that created it.
> at org.apache.xerces.dom.ParentNode.internalInsertBefore(Unknow n
> Source)
> at org.apache.xerces.dom.ParentNode.insertBefore(Unknown Source)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.forceNiceInser tBefore(XSDConcreteComponentImpl.java:1590)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.niceInsertBefo re(XSDConcreteComponentImpl.java:1514)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.handleElementF orAdopt(XSDConcreteComponentImpl.java:1367)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:366)
> Does anybody have a hint?
> Kind regards,
> klaus
<html>
<head>
http-equiv="Content-Type">
</head>
Klaus,<br>
<br>
I don't understand how it got past <b>this </b>guard:<br>
<br>
Re: Schema Merging [message #72203 is a reply to message #72185] |
Fri, 27 April 2007 09:41 |
Klaus Schaefers Messages: 24 Registered: July 2009 |
Junior Member |
Ed Merks wrote:
> Klaus,
> are seeing...
>> error:
>> Source)
>> at
>> at
>> at
>> at
>> Kind regards,
>> klaus
>>Thankx, it works. Do I have to take care of the namespaces of the elements
by my self, or does EMF that work for me?
Klaus
Re: Schema Merging [message #72221 is a reply to message #72203] |
Fri, 27 April 2007 10:29 |
Klaus,
I was going to mention that it's tricky since references will be to
things in other namespaces and when copying them over, they will still
want to refer to those same namespace. So yes, if you want something to
refer to a different namespace, you have to do the visiting and the
transforming to make that happen. Probably an
XSDUtil.XSDNamedComponentCrossReferencer will help. You can apply it to
the final schema to find all the references to named components. I
think that for each named component that's a key in the map and that's
not resolved (for which getContainer() is null), you'd want to use
resolveXyz of the new namespace and the old local name to find where it
should resolve, and then use EcoreUtil.replace(setting,
oldNamedComponent, newNamedComponent) for the setting that's the value
in the map.
> Ed Merks wrote:
>> Klaus,
>> != getElement().getOwnerDocument()*)
>> DOM. (And you'd probably be better off doing an addAll instead of
>> adding one at a time.) Using
>> XSDConcreteComponent.cloneConcreteComponent(true, false) and adding a
>> clone might be a way to avoid whatever problem you are seeing...
>>> Hi,
>>> following error:
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> Kind regards,
>>> klaus
>>> elements
> Cheers,
> Klaus
Re: Schema Merging [message #602327 is a reply to message #72167] |
Ed Merks Messages: 33216 Registered: July 2009 |
Klaus,
are seeing...
> error:
> Source)
> at
> at
> at
> at
> Kind regards,
> klaus
<html>
<head>
</head>
Klaus,<br>
<br>
<br>
Ed Merks
Re: Schema Merging [message #602332 is a reply to message #72185] |
Junior Member |
Ed Merks wrote:
> Klaus,
> are seeing...
>> error:
>> Source)
>> at
>> at
>> at
>> at
>> Kind regards,
>> klaus
Klaus
Re: Schema Merging [message #602336 is a reply to message #72203] |
Klaus,
in the map.
> Ed Merks wrote:
>> Klaus,
>>> Hi,
>>> following error:
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> Kind regards,
>>> klaus
>>> elements
> Cheers,
> Klaus
Ed Merks
Current Time: Wed Sep 18 16:43:34 GMT 2024
Powered by FUDForum. Page generated in 0.04230 seconds
