How To Debug Using GDB [message #71980] |
Wed, 28 May 2003 13:31  |
Originally posted by: edubez.hotmail.com
I'm having a hard time trying to debug from inside Eclipse
using MinGW on Windows XP Pro.
When I try to debug I receive the following error:
"No symbol table is loaded. Use the file command"
I have reproduced the FAQ example, it compiles and run
without trouble but I can't debug.
Any suggestions ?
Eduardo
Re: How To Debug Using GDB [message #72645 is a reply to message #72092] |
Sun, 01 June 2003 14:01  |
After removing the spaces from the project path and adding the
-g compiler switch I was able to debug my sample project.
Thank you for the help.
Eduardo
"Mikhail Khodjaiants" <mikhailk@qnx.com> wrote in message
news:bb2vf8$hs6$1@rogue.oti.com...
> Check if the path of your executable contains spaces.
> "Eduardo Bezerra" <edubez@hotmail.com> wrote in message
> news:bb2ror$e8k$1@rogue.oti.com...
> > Hi,
> > Any suggestions ?
> > Thanks,
> > Eduardo
FUDForum. Page generated in 0.04819 seconds
