Problem using VE on OS X - Error trying to set new file into editor [message #6437] |
Sat, 29 November 2003 15:40 |
Originally posted by: adam.isetta.brtinc.com
I've got VE installed on my Mac (10.3, JDK 1.4.1), and can create a VE
project successfully.
However, when I open the editor, VE reports "Error trying to set new file
into editor" "Reason:
java.lang.NullPointerException".
The preview window begins to render, but stops with a "Loading"
notification. The code editor is
open, but the left hand "palette" pain never loads.
TIA!
Adam
Re: Problem using VE on OS X - Error trying to set new file into editor [message #10889 is a reply to message #10876] |
Fri, 12 December 2003 14:12 |
Originally posted by: mendelgili.netscape.net
Eric DeWitt wrote:
> In article <bqag0q$hqn$1@eclipse.org>,
> Gili Mendel <mendelgili@netscape.net> wrote:
>>https://bugs.eclipse.org/bugs/show_bug.cgi?id=47716
> I too had this problem (and noticed the existing bug report so I didn't
> refile it. ;-) But, this is not mentioned anywhere that I saw while
> reviewing the VE release information. It really should be noted in the
> FAQ (which suggest that VE supports all Eclipse platforms) and also on
Yep.
> the download page (which suggests the same). It also would be nice to
> have some comment on expected date or release where MacOS X will be
> fully supported. I, for one, would be glad to provide debug
> information, etc. to try to help get MacOS X up to speed.
Note that MacOS support on 2.1 is considered "early
access" (see https://bugs.eclipse.org/bugs/show_bug.cgi?id=37708).
We will make an attempt to get VE on this platform in the v1.0.0/Elipcse
3.0 time frame. We have not tried VE on MacOS thus far mainly because
of time constraints. Hence, we do not fully understand if there are any
show stoppers on this platform for VE.
Tks. for the debug help offer; we will probably take you up on later on.
FUDForum. Page generated in 0.03458 seconds
