Eclipse 3.0 M1 and Linux [message #71870] |
Wed, 02 July 2003 18:50 |
Originally posted by: abochert.tooligan.com
Hi!
I have a question: I try to run Eclipse 3.0 M1 under Linux (Mandrake 9.1).
Java-SDK (1.4.2) has been installed, PATH properly extended I get however
an error starting eclipse: an XML-file (plugin.xml) couldn't be parsed...
What is wrong?
Thanks for every answer
Artur
Re: Eclipse 3.0 M1 and Linux [message #71891 is a reply to message #71870] |
Wed, 02 July 2003 19:19 |
Starting Eclipse for the first time (please wait... complete the
install...)
Error dialog: Problems during startup. Check the \".log\" file in the
\".metadata\" directory of your workspace.
/home/artur/workspace/.metadata/.log:
!SESSION lip 02, 2003 19:10:22.73
java.version=1.4.2
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=pl_PL
Command-line arguments: -os linux -ws gtk -arch x86 -install
file:/home/artur/Apps/eclipse/
!ENTRY org.eclipse.core.runtime 2 1 lip 02, 2003 19:10:22.74
!MESSAGE Problems encountered loading the plug-in registry.
!SUBENTRY 1 org.eclipse.core.runtime 2 1 lip 02, 2003 19:10:22.74
!MESSAGE Parsing error in \"plugin.xml\" [line -1, column -1]:
\"Unexpected end of file\".
!STACK 0
org.xml.sax.SAXParseException: Unexpected end of file.
org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseExc eption(ErrorHandlerWrapper.java:232)
org.apache.xerces.util.ErrorHandlerWrapper.fatalError(ErrorH andlerWrapper.java:213)
org.apache.xerces.impl.XMLErrorReporter.reportError(XMLError Reporter.java:366)
org.apache.xerces.impl.XMLErrorReporter.reportError(XMLError Reporter.java:296)
org.apache.xerces.impl.XMLScanner.reportFatalError(XMLScanne r.java:1244)
org.apache.xerces.impl.XMLDocumentScannerImpl$XMLDeclDispatc her.dispatch(XMLDocumentScannerImpl.java:608)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(XMLDocumentFragmentScannerImpl.java:333)
org.apache.xerces.parsers.StandardParserConfiguration.parse( StandardParserConfiguration.java:525)
org.apache.xerces.parsers.StandardParserConfiguration.parse( StandardParserConfiguration.java:581)
at org.apache.xerces.parsers.XMLParser.parse(XMLParser.java:147 )
org.apache.xerces.parsers.AbstractSAXParser.parse(AbstractSA XParser.java:1158)
org.eclipse.core.internal.plugins.PluginParser.parsePlugin(P luginParser.java:472)
org.eclipse.core.internal.plugins.RegistryLoader.processMani festFile(RegistryLoader.java:89)
org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathFile(RegistryLoader.java:136)
org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathEntry(RegistryLoader.java:127)
org.eclipse.core.internal.plugins.RegistryLoader.processMani festFiles(RegistryLoader.java:104)
org.eclipse.core.internal.plugins.RegistryLoader.parseRegist ry(RegistryLoader.java:63)
org.eclipse.core.internal.plugins.RegistryLoader.parseRegist ry(RegistryLoader.java:71)
org.eclipse.core.internal.runtime.InternalPlatform.parsePlug ins(InternalPlatform.java:890)
org.eclipse.core.internal.runtime.InternalPlatform.loadRegis try(InternalPlatform.java:834)
org.eclipse.core.internal.runtime.InternalPlatform.loaderSta rtup(InternalPlatform.java:684)
org.eclipse.core.internal.boot.InternalBootLoader.startup(In ternalBootLoader.java:1040)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:838)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!SUBENTRY 1 org.eclipse.core.runtime 2 1 lip 02, 2003 19:10:22.78
!MESSAGE Error while processing
\" file:/home/artur/Apps/eclipse/plugins/org.eclipse.jdt_2.1.0/ plugin.xml\ ".
File /home/artur/Apps/eclipse/plugins/org.eclipse.jdt_2.1.0/plugi n.xml:
<?xml version=\"1.0\" encoding=\"UTF-8\"?>
<plugin
name = \"%pluginName\"
id = \"org.eclipse.jdt\"
version = \"2.1.0\"
provider-name = \"%providerName\">
</plugin>
Re: Eclipse 3.0 M1 and Linux [message #73631 is a reply to message #71891] |
Mon, 07 July 2003 17:36 |
Originally posted by: jared-eclipse.mn.rr.com
The stack trace says unexpected end of file. Sounds like your install is
corrupt. Maybe you got a bad download or unzipped the archive incorrectly
(using jar instead of unzip?)?
- Jared
> install...)
> java.version=1.4.2
> !STACK 0
FUDForum. Page generated in 0.03996 seconds
