Home » Archived » Higgins » Eclipse Releases Its First User-Centric Identity Framework
Eclipse Releases Its First User-Centric Identity Framework [message #6405] Thu, 21 February 2008 14:29 Go to next message
Originally posted by: mary.socialphysics.org
Today, Eclipse announced the release of Higgins 1.0!
The press release can be found at
http://www.businesswire.com/portal/site/google/?ndmViewId=ne ws_view&newsId=20080221005140&newsLang=en
Many thanks to all who worked so hard to make this happen. This is a major
milestone in the development of user-centric systems.
Re: Eclipse Releases Its First User-Centric Identity Framework [message #6426 is a reply to message #6405] Fri, 22 February 2008 20:32 Go to previous messageGo to next message
Originally posted by: udaykabe.hotmail.com
Mary,
I was excited to read this bit of news today. I wanted to try out the RCP
app, so I checked out the necessary Higgins projects via the psf file. The
product exports OK and runs well enough. However, my attempt to import my
CardSpace store failed because the app couln't decrypt the store. Have you
seen this before and, if so, what is the resolution?
Also I am using Eclipse 3.2, and I noticed some Eclipse 3.3 plugins
mentioned in the product list. Is this app and Higgins meant to run on 3.3?
Thanks in advance.
Uday
"Mary Ruddy" <mary@socialphysics.org> wrote in message
news:bead1c9b414e41f38632468dd5c206c8$1@www.eclipse.org...
Re: Eclipse Releases Its First User-Centric Identity Framework [message #6501 is a reply to message #6426] Mon, 10 March 2008 15:51 Go to previous messageGo to next message
Uday,
Please enter a bugzilla item for your import problem.
Higgins doesn't require Eclipse per se as it needs to be able to run in
both Eclipse and non-Eclipse enivronments. What specific reference made
you think that it might? (Sorry for the delayed response.)
Re: Eclipse Releases Its First User-Centric Identity Framework [message #6561 is a reply to message #6426] Tue, 18 March 2008 13:37 Go to previous message
David Campos Vall is currently offline David Campos VallFriend
I had your same problem with stores and trying to create new stores.
My problem came associated to some InvalidKeySize exceptions or
CardsStoreDecrypt exceptions (last one is not exactly this).
The reason of the problem comes because the encryption policy associated
to your java virtual machine (JVM) its not the strong one. For solve it
just download and install the JCE related with your runtime version.
http://java.sun.com/javase/downloads/index_jdk5.jsp for JDK - JRE 1.5
http://java.sun.com/javase/downloads/index.jsp for JDK - JRE 1.6
http://java.sun.com/j2se/1.4.2/download.html for JDK - JRE 1.4.2
The download link its at the bottom of each page.
Re: Eclipse Releases Its First User-Centric Identity Framework [message #562338 is a reply to message #6405] Fri, 22 February 2008 20:32 Go to previous message
Mary,
Thanks in advance.
Uday
Re: Eclipse Releases Its First User-Centric Identity Framework [message #562449 is a reply to message #6426] Mon, 10 March 2008 15:51 Go to previous message
Mary Ruddy is currently offline Mary RuddyFriend
Uday,
Re: Eclipse Releases Its First User-Centric Identity Framework [message #562526 is a reply to message #6426] Tue, 18 March 2008 13:37 Go to previous message
Previous Topic:shangrila.parityinc.net:8888
Next Topic:An issue happens when deploying STS
Current Time: Thu Dec 26 21:58:09 GMT 2024
Powered by FUDForum. Page generated in 0.03246 seconds
