Re: Eclipse Releases Its First User-Centric Identity Framework [message #6426 is a reply to message #6405] |
Fri, 22 February 2008 20:32 |
Originally posted by: udaykabe.hotmail.com
Mary,
I was excited to read this bit of news today. I wanted to try out the RCP
app, so I checked out the necessary Higgins projects via the psf file. The
product exports OK and runs well enough. However, my attempt to import my
CardSpace store failed because the app couln't decrypt the store. Have you
seen this before and, if so, what is the resolution?
Also I am using Eclipse 3.2, and I noticed some Eclipse 3.3 plugins
mentioned in the product list. Is this app and Higgins meant to run on 3.3?
Thanks in advance.
Uday
"Mary Ruddy" <mary@socialphysics.org> wrote in message
news:bead1c9b414e41f38632468dd5c206c8$1@www.eclipse.org...
> Today, Eclipse announced the release of Higgins 1.0!
> The press release can be found at
> http://www.businesswire.com/portal/site/google/?ndmViewId=ne ws_view&newsId=20080221005140&newsLang=en
> Many thanks to all who worked so hard to make this happen. This is a major
> milestone in the development of user-centric systems.
Re: Eclipse Releases Its First User-Centric Identity Framework [message #6501 is a reply to message #6426] |
Mon, 10 March 2008 15:51 |
Originally posted by: mary.socialphysics.org
Uday,
Please enter a bugzilla item for your import problem.
Higgins doesn't require Eclipse per se as it needs to be able to run in
both Eclipse and non-Eclipse enivronments. What specific reference made
you think that it might? (Sorry for the delayed response.)
FUDForum. Page generated in 0.03737 seconds
