Home » Eclipse Projects » GEF » Create GEF Editor like the Compare Editor
Create GEF Editor like the Compare Editor [message #71397] Tue, 18 March 2003 22:44 Go to next message
Hal is currently offline HalFriend
Member
How can I create a GEF Editor like the Compare Editor in eclipse?
In the compare editor, it has 2 Editors pane (one on left, one on right) and
each has a hort scroll bar, but only 1 vertical scroll bar. And when I
scroll the vertical scroll bar, both editor scrolls.
Can I do that in GEF Editor?
Thank you.
Re: Create GEF Editor like the Compare Editor [message #71417 is a reply to message #71397] Tue, 18 March 2003 23:31 Go to previous message
Create two ScrollingGraphicalViewers. Do a
FigureCanvas.setVerticalScrollBarVisibility(false) on both viewers, and
construct your own Scrollbar widget external to the viewers.
Synchronizing the scrolling would be another issue, probably the hardest
part.
"Hal" <otaconss2@hotmail.com> wrote in message
news:b587i0$gl7$1@rogue.oti.com...
and
> Thank you.
Previous Topic:Popup Menu
Next Topic:Wire in Logic Editor Example
Current Time: Wed Feb 05 06:50:09 GMT 2025
Powered by FUDForum. Page generated in 0.05006 seconds
