Home » Eclipse Projects » Equinox » plugin startup configuration
plugin startup configuration [message #71211] Tue, 01 August 2006 16:21 Go to next message
Originally posted by: duncan.krebsnet.com
First I just want to say thank you to the folks who have been working in
the incubator. With some help I've got a working platform that includes a
port of JSF, AXIS as well as a way to define jsp folders off the plugin
root and map the real path to a virtual path in the browser. Now I'm
working on a higher level templating system that can reference jsps by
their virtual paths, good stuff.
One detail however that is really starting to bug me is the fact that the
plugin that handles the jsp mapping always has to be manually started in
the OSGI console using the start command. I've tried everything from
changing the start-level to a lower and higher number, to removing the
eclipse-lazystart property in the manifest, to changing the value in the
launch configuration to say true to launch. But for the life of me, when I
start the OSGI configuration the bundle's initial state is always set to
RESOLVED and not ACTIVE. It seems to be doing this on 2 plugins in my code
and I'm wondering if anyone has any ideas. - Duncan
Re: plugin startup configuration [message #71237 is a reply to message #71211] Wed, 02 August 2006 02:31 Go to previous messageGo to next message
Originally posted by: nickylavignevn.gmail.com
You can add @start at the end of the name of jar file to force it start
after installed. For examples test.jar@start
"Duncan Krebs" <duncan@krebsnet.com> wrote in message
news:b4d71d2ee52a1233c433d0694a80c90e$1@www.eclipse.org...
Re: plugin startup configuration [message #71316 is a reply to message #71237] Wed, 02 August 2006 13:48 Go to previous messageGo to next message
I simply added the @start after the plugin name in the launch
configuration and it worked. I might be missing something but I could not
find a way to achieve the @start configuration for a plugin using the
dialog editor in the Run.. menu. It would either do @:true or @1:default
if the start level was changed and the start option will set true,default
or false but never start, although now I don't care!
Re: plugin startup configuration [message #71449 is a reply to message #71316] Thu, 03 August 2006 14:24 Go to previous message
Duncan Krebs wrote:
> Thanks, I simply added the @start after the plugin name in the launch
> not find a way to achieve the @start configuration for a plugin using
> the dialog editor in the Run.. menu. It would either do @:true or
> @1:default if the start level was changed and the start option will set
> true,default or false but never start, although now I don't care!
This sounds like a bug in PDE-UI. Can you please open a bug against
PDE-UI. It should not stick stuff like @1:default or @:true in the
generated config.ini.
Tom.
Previous Topic:Error when start Equinox
Next Topic:Export-Package mandatory directive
Current Time: Wed Oct 22 06:16:06 EDT 2025
Powered by FUDForum. Page generated in 0.05748 seconds
